*what does this fuse do?*
Old Mar 8, 2003
Da1lyDr1ver's Avatar
does anyone know EXACTLY what the fuse named "BACKUP" does on our cars??? i think its located under our dash or something. i'm trying to figure out because this fuse is causing a drain on my battery.
Old Mar 8, 2003
twizzx's Avatar
twizzx is an unknown quantity at this point
When I blew that fuse once, my keyless entry stopped working. Once I replaced it it worked again. Hope this helps!
Old Mar 8, 2003
Quote
[hr]keyless entry stopped working[hr]
interesting, but do you know if it affects anything else other than the keyless entry system?? thanks
Old Mar 8, 2003
Dr5D's Avatar
what happens if you take it out? wouldent that tell you?
Old Mar 8, 2003
born2xLr8's Avatar
Have you checked out your manual? It gives some info on fuses in your car.
Old Mar 8, 2003
jkim1978's Avatar
jkim1978 is an unknown quantity at this point
aren't backups... just extra fuses..? that's what i thought.... or am i wrong... ?
Old Mar 8, 2003
Cokafka's Avatar
Cokafka is an unknown quantity at this point
The back up fuse when blown, or removed (in my case) will cause your light/key reminder to stop buzzing, it will cause your gauges to flutter when you roll the ignition, and a few other things if I am not mistaken.
Old Mar 8, 2003
twizzx's Avatar
Quote
[hr]Originally posted by: Dr5D
what happens if you take it out? wouldent that tell you?[hr]
Only if it were that simple
Old Mar 8, 2003
twizzx's Avatar
I think it's best to talk to a tech at your dealer. I know for sure that one use is for keyless entry, but honestly I do not know what else it is hooked up to.
Old Mar 8, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Fuse Number 9 (BACKUP): 10 Amp; Connects to a white/red wire; Data link connector (DLC), Gauge assembly, Immobilizer receiver unit, Keyless reciever unit, Multiplex control unit, Security control unit, Audio unit
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
Klame9420
Sep 18, 2015 12:37 PM
Mc7602
Sep 17, 2015 02:01 PM
h4ldol
Sep 17, 2015 01:25 PM
