help!! Center Dash
Old Mar 5, 2003
KeNsHiN's Avatar
LEVA
help!! Center Dash
i am changing my lights "blue" and i can't get my center dash out, i did search and i only found a picture from AK that read "stick your hand behind that bar, and you will feel another bar. Push that bar up! It will pop the center dash." but i don't feel that other bar[IMG]i/expressions/face-icon-small-confused.gif[/IMG]has anyone else had this problem?
please help it's cold outside...............
Old Mar 5, 2003
CarbonFly's Avatar
I don't know waht he was talkin about when he said "push the bar up". Here is how I did it. I took a flathead screw driver and just pried it from the edges very carefully.
Old Mar 5, 2003
KeNsHiN's Avatar
LEVA
Quote
[hr]Originally posted by: FlyRiceRacer02
I don't know waht he was talkin about when he said "push the bar up". Here is how I did it. I took a flathead screw driver and just pried it from the edges very carefully.[hr]
LOL, thats what i have been doing!!LOL well ok i guess i will just keep doing that then[IMG]i/expressions/face-icon-small-nono.gif[/IMG] i feel like it's going to break
Old Mar 5, 2003
CarbonFly's Avatar
Basically there are 2 clips for each corner. Start with the left side, stick the prying tool right in the middle of the left side. Push all the way in. Slowly pull out. Some of the plastic edge may bend. Just be careful.
Work your way up and down the side until the clips on that side pop out. Do this for all sides. And you can push in the back of your CD player to help.
Old Mar 5, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
if your just gonna do the ac controls pop off the **** and then stick end of knife in hle and pop out lil cirlce pop out ornage or greensh stuff and pout in blue no need to take apart dahs except to chnage cd player.. now wasnt that easy and when you put it back together the ***** only fit in one spot so you dont mix anything up...
riley
whole thing discovered accendentally when i droped mine and all three cirlces popped out.
Old Mar 5, 2003
7thGenerasianCivic's Avatar
DON'T PRY PLEASE! Prying is bad...[IMG]i/expressions/face-icon-small-nono.gif[/IMG] ak means that there is a metal bar(where you unskrewed the two bolts). There is also another one RIGHT ON TOP OF IT( laying on it!) push that one towards you and up. With a little [IMG]i/expressions/face-icon-small-mad.gif[/IMG]power it will work!
Old Mar 5, 2003
CarbonFly's Avatar
Quote
[hr]Originally posted by: 7thGenerasianCivic
DON'T PRY PLEASE! Prying is bad...[IMG]i/expressions/face-icon-small-nono.gif[/IMG] ak means that there is a metal bar(where you unskrewed the two bolts). There is also another one RIGHT ON TOP OF IT( laying on it!) push that one towards you and up. With a little [IMG]i/expressions/face-icon-small-mad.gif[/IMG]power it will work![hr]
Prying is not bad. I did it with mine and had ZERO problems. There is no bar. Maybe because I have an after market head unit and kit I don't have the bar anymore. I dunnno. But prying is fine.
Old Mar 5, 2003
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Did you take out the 2 screws that are holding the center dash on..?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 5, 2003
FBIWannabe's Avatar
FBIWannabe is an unknown quantity at this point
i broke 2 or 3 of my clips when trying to pull up on the bar but i guess that was cause the dash was coming out at an angle the bottem half came out first then when i pulled it out the top 3 clips broke ::shrugs::
Old Mar 5, 2003
CarbonFly's Avatar
Quote
[hr]Originally posted by: Hefe
Did you take out the 2 screws that are holding the center dash on..?[IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
You have 2 screws holding the dash on?
Old Mar 5, 2003
skipbarber's Avatar
Quote
[hr]Originally posted by: FBIWannabe
i broke 2 or 3 of my clips when trying to pull up on the bar but i guess that was cause the dash was coming out at an angle the bottem half came out first then when i pulled it out the top 3 clips broke ::shrugs::[hr]
that just makes it a hell of alot easier to take it off again if you want to change your head unit again. when i did mine, like two or three clips fell off and down into the dash.... ::shrugs::
Old Mar 5, 2003
outdrsmn80's Avatar
outdrsmn80 is an unknown quantity at this point
Quote
[hr]Originally posted by: rijowysock
riley
whole thing discovered accendentally when i droped mine and all three cirlces popped out.[hr]
Holy Crap....are you drunk??? You need to either lay off the booze or go buy a new keyboard. [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 5, 2003
Hefe's Avatar
Quote
Quote
You have 2 screws holding the dash on?[hr]
I HAD 2.. until i dropped one into the "abyss"... didn't you have screws hold your dash piece on... I'm talking about the 2 when you pop off the power outlet piece then look straight up an see the 2 screws...
Old Mar 5, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Read this DIY from "Get down low and you will see ...."
Old Mar 5, 2003
Hefe's Avatar
Yes thank you AK... those 2 screws....
Old Mar 6, 2003
twizzx's Avatar
twizzx is an unknown quantity at this point
After you take the screws out, try this. Take a useless credit card and slide in the top of the center dash. This will you give separation. Now just on the back of the credit card and the top definitely will pop out. I know it feels like you are going to bend it but you just have trust that it won't. (well hopefully not). After the top clips are out the other ones are easy. Now, just use a combination of pull of the center dash and push of the bar. This worked for me.
Old Mar 6, 2003
MadWheel's Avatar
Premium Boosted Member
Mine was a paint at first, prying, pulling pushing...Now I take it out within 10-15 seconds (good or bad lol). After the bottom two screws come out, if you end up prying it, wrap a flathead with a thin rag so you dont scratch and pieces if the screw driver slips.
h4ldol
Apr 24, 2017 08:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
hondacivic0253
Sep 29, 2015 08:06 AM
Klame9420
Sep 18, 2015 12:37 PM
