What is a mass airflow sensor?
what is a mass airflow sensor? what does it do? cause my friend has 01' Celica and said after cleaning out the maf sensor he's car seems to running better. Does my civic has one too? if so how can i clean it? thanks.
The MAF is that thing that plugs into your intake. I think all cars have them.
Ever seen these ebay sellings? All it does it put a resistor on your MAF and this causes the suppposed increase performance.
The mass airflow sensor (MAF) senses the amount of air going into the engine so air/fuel ratio can be managed. Sometimes a temperature sensor is also placed on the intake farther away from the throttle body where there is less heat so the engine thinks the air is cooler and the ecu changes the timing to take advantage of the colder air. Hope this helps.
R/T
R/T
Quote
[hr]Originally posted by: FlyRiceRacer02
Ever seen these ebay sellings? All it does it put a resistor on your MAF and this causes the suppposed increase performance.[hr]
Quote
[hr]Originally posted by: PESTLNC
That's not the MAF sensor, that's the IAT sensor (Intake Air Temperature).[hr]
Quote
I don't think our cars even have a MAF sensor, but I'm not completely sure. I believe our ECU estimates the amount of oxygen entering the intake by the temperature read from the IAT and the position of the TPS (Throttle Position Sensor).
As for cars with a MAF, cleaning a dirty one will certainly improve how the car runs. A big problem with people with K&N filters is that the oil tends to fly off and stick to the MAF's wires causing the ECU to think the car is running lean.
DIY King
Quote
As for cars with a MAF, cleaning a dirty one will certainly improve how the car runs. A big problem with people with K&N filters is that the oil tends to fly off and stick to the MAF's wires causing the ECU to think the car is running lean.[hr]
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
mistermenphis22
Jul 13, 2015 04:43 PM
