Turbocharging the Civic Ex 1.7L
Old Feb 14, 2003
mxm477's Avatar
mxm477 is an unknown quantity at this point
Matt here,
I got excellent responses from my question... thanks, so I ran the calculations, and...
I was not aware of the factory 9.9:1 compression ratio. This is a very difficult engineering hurdle to overcome if the engine is to be turbocharged. Even 4 psi of boost moves 17.0 #/min of air, this brings the effective CR to 10:5:1... okay for super unleaded pump gas... go to 6 psi boost and find yourself moving 17.9 #/min of air, and having a CR over 11:1... translation... octane rating of over 100 is required.
So, there are some answers to the boosting question:
1. Hydromethane injection (low pressure): Stabilize the flame front of the combustion event and arrest pre-ignition. Disadvantage: This will add cost, and packaging constraints are already high. Conclusion: It can be done. Extra: This is how the 2003 Lancer EVO VIII develops 280 hp from 2.0L.
2. Run rpm range to 8500, even 9000 rpm. Another major problem with the Civic Ex is that the Volumetric Efficieny of the engine is so high. Translation: 4 valves per cylinder with V-Tec equals ~90% VI... the engine does a fantastic job of packing the cylinders via NA. SO... non-VTec engines are much easier to boost becuase they need inlet pressure to pack the cylinders. Conclusion: Running in the 8000 rpm range is a great place for boosting, becuase the engine VA goes down (50-60%). Putting the boost when the engine cannot pack its cylinders makes for major hp. Conclusion: Not a big problem to overcome technically, but are you willing to run your engine to 8500 rpm?
3. Increase bump height: Take off the cylinder head and increase the head gasket thickness thus reducing the CR. Or, to go even further, change the pistons or the bowl volume in the head. Conclusion: This is too difficult for most people to accomplish, and way to expensive.
So, 160 - 175 hp is a much more realistic goal for a do-it-yourself, and will keep the cost below $3500.
At 160 hp, the Civic will run the 1/4 mile is14.7 sec, at 175 hp, it will run it at 14.23 sec... not too shabby (air temp 68°).
I am interested to read your feedback based on this information...
Old Feb 14, 2003
Barney's Avatar
Barney should not be trustedBarney should not be trustedBarney should not be trusted
Me:
Port and polished head,
Goldeneye sleeved block,
Shot peened rods,
Manly valves,
JE pistons,
Haltech F5 computer ,
Extra injector,
Return fuel system,
ACT clutch,
ACT Flywheel,
Crank pulley,
No a/c,
No power steering,
2 inch exhaust,
2 inch downpipe,
No cat,
T3 turbo,
Zex plugs,
Delta waste gate,
Greddy blow off valve,
Spearco intercooler,
NX intercooler for intercooler,
25 shot of nitrous express for faster spooling,
Drag radials
Custom cooper gasket,
10 psi of boost
I only ran a 13.56 @ 108
Later, Phil
EDIT: I will run again with 15 psi. As of now I don't have a dyno run to scan, sorry.
Old Feb 14, 2003
jamesbbh's Avatar
jamesbbh is an unknown quantity at this point
wow matt youve been doing your homework lol good job man
Old Feb 14, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
I've witnessed a 7th gen with 75 shot of N20 hit a 14.2 at 94mph.
Old Feb 14, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
matt, thats some good infos....
Old Feb 15, 2003
CIVIC2NV's Avatar
CIVIC2NV is an unknown quantity at this point
WOW!!!!!
That is some crazy stuff..
hey barney how much did all that cost u, can u give me prices?
I want my car to go that fast!!!
hey Barney u have any messenger services aol,msn,yahoo, if u dont mind I need to know a bit of stuff on some things u have
Nice Job Matt
Hey matt how about the 2001 LX how would that do, any possobilities?
Old Feb 15, 2003
Grey's Avatar
DIY King
Using this...
EX:
Bore: 75mm or 2.95 inches
Stroke: 94.4mm or 3.72 inches
VE: 90%
C/R: 9.9:1
Boost Pressure: 6psi
Boost C/R: 12.3:1
Reccomended Octane: 102
LX:
VE: 80%
C/R: 9.5:1
Boost C/R: 10.6:1
Reccomended Octane: 97
But, the VE changes from with rpm as you said, so... Try this
Rod length: ~140mm or 5.52 inches (got this from: The Super D-Series Piston Comparo)
Inlet Valve Closes ABDC: A guess at 45 degrees.
Altitude: sea level (0 feet)
For EX: 12.63:1 C/R
For LX: 12.12:1 C/R
Hmm... I don't know for certain the VE's of our cars and I don't know for certain the Inlet Valve Closes ABDC. Anyone?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
cloudguy
Apr 28, 2015 05:02 AM
LionSpratt
Apr 26, 2015 01:02 PM
smmahan
Apr 15, 2015 08:17 PM
Cilvic
Nov 15, 2001 04:54 PM
WeRkX
Nov 1, 2001 10:33 PM
