My temperature needle is at H
Old Jan 19, 2003
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
One time i hit on a curb wasn't that fast...........and i think i f*k up my radiator...
i was wondering how much these will be cost?.... and labour..
thanks
eric
Old Jan 19, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
here
look around for a used one. A new OEM one is $199US
BTW: did u mess up ur bumper when you hit the curb?
Old Jan 19, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Open the radiator and make sure you have enough antifreeze...also, when your car is parked and off, do you smell like a hot/musty smell? Thats what a bad radiator smells like......
Old Jan 19, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
u hit the curb?when?and u wanna lower your car even more!!!!!![IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 19, 2003
Baghead's Avatar
Baghead is an unknown quantity at this point
i dont know where the water pump is located in our cars, but you might have messed it up. if its not pumping water to cool the engine overheating occurs and you are screwed.
Old Jan 19, 2003
greg2k1's Avatar
greg2k1 is an unknown quantity at this point
buddie if there is no water pumping out...you have a problem...you engin is going to be messed up[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 19, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
When i was rearended then i hit a curb my radiador also got damaged i bent it like in half and all they did was replace it at the dealer.I think it wa 250 but my incur. payed for it Maybe that helps
Old Jan 19, 2003
MaxPSiLX's Avatar
MaxPSiLX is an unknown quantity at this point
You should be able to get it supplemented to the estimate if it happened during your accident. Just take it back and tell them it didn't start until you were rearended and you did run up on a curb....better than paying it out of pocket.
Old Jan 20, 2003
Elite's Avatar
Elite is an unknown quantity at this point
Quote
[hr]Originally posted by: Mystic3030
Open the radiator and make sure you have enough antifreeze...also, when your car is parked and off, do you smell like a hot/musty smell? Thats what a bad radiator smells like......[hr]
what does a hot/musty smell like? I am curious cuz I have never had a bad radiator
Old Jan 20, 2003
Mystic3030's Avatar
Quote
[hr]Originally posted by: Elite
Quote
what does a hot/musty smell like? I am curious cuz I have never had a bad radiator[hr]
Im not really sure how to describe the smell....open up your radiator and smell it...thats the closest your gonna get to the way it smells....if you can smell that outside the car after its been running, then you have problems.
Old Jan 20, 2003
pleasejoe's Avatar
pleasejoe is an unknown quantity at this point
well it could jus be your lower radiator hoses, but it could be alot of other things. whens the last time you change the coolant? or check the pcv see if it even works, theres alot of things that can attribute to overheating, liek dragging brakes, you should go get it checked out at a shop
Old Jan 20, 2003
solar's Avatar
solar is an unknown quantity at this point
Make sure that your radiator fan is working, you may have messed that up and not have a problem with your radiator.
raymondxcho
Sep 29, 2015 09:00 PM
NROD315
Sep 23, 2015 03:46 PM
Bruce2
Sep 21, 2015 08:01 PM
MamaBear2015
Sep 15, 2015 09:35 PM
Dave Brabant
Sep 10, 2015 06:48 PM
