Compression Ratio -- S2000Man or anyone else...
Old Dec 24, 2002
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Can someone explain what a compression ratio is? And what the #s would stand for... i.e, 10:5:1... what is it an actual ratio of? fuel? air? Thanks!
Old Dec 24, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Your compression ratio is the volume of the cylinder at bottom dead center divided by the volume of the cylinder at top dead center.
There is no 10:5:1, but there is 10:1 stating that at BDC, the volume is ten times greater than at TDC.
Old Dec 24, 2002
S2000man01's Avatar
O RLY
Yup. so if the volume of the combustion chamber (where the cylinder is) is 550cc's when the piston is at BDC, and the piston displaces 500cc's during the compression stroke, then that leaves 50cc's left in the combustion chamber.
So 550/50 = 11:1 compression ratio.
10:5:1 isn't a possible ratio, but 10.5:1 is. [IMG]i/expressions/face-icon-small-smile.gif[/IMG] And since it is a ratio, the 2nd number will ALWAYS be 1.
and just to throw more knowledge your way, because of the way fuel/air mixes and engines work, 14:1 is about the highest compression attainable, but that is on the highest octane race gas and more than likely with detonation! [IMG]i/expressions/face-icon-small-smile.gif[/IMG] You can get higher compression than that, but you'd have some serious detonation problems!
Old Dec 24, 2002
Grey's Avatar
DIY King
And just to add to this...
The formula for finding the effective compression is very easy: ((boost psi / 14.7) + 1) x motor compression = effective compression.
So... Let's calculate the maximum psi that we can acheive with the stock compresison ratio.
With the proper fuel system and related engine components, an effective compression of 16:1 to 18:1 should be more than workable. For heavily modified cars, effective compressions over 20:1 should be very carefully considered.
For an LX (9.5:1):
((effective compression / motor compression) - 1) x 14.7 = boost
((18 / 9.5) - 1) x 14.7 = 13.2
So 13psi is the highest that we can run (assuming an effective compression ratio of 18:1) with the stock compression ratio of an LX.
For an EX (9.9:1):
((18 / 9.9) - 1) x 14.7 = 12.0
Just something to take into consideration when building a turbocharged D17. Most of this was re-hashed from: MotorSports Digest
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
Sep 27, 2015 11:33 AM
NROD315
Sep 12, 2015 02:46 PM
darwin-t
Aug 15, 2015 10:51 AM
