Any tips on removing center trim piece
Any Tis on removing center trim piece
I'm tryin to pain my center trim piece and i cant get the thing out for anything. I have searched and looked at all the DIY's that deal with removing it nothing seems to work. Thanks
Remove the bottom piece (where the cig lighter sits)
Now look inside..... look up and you will see 2 bolts (8 or 10mm)
Remove those .....
Now stick your hand in there (behind the bar) and push it up with force.
If that fails, you can try to pop the center piece by prying it all around with a small flat head screwdriver.
edit #1:
VERY GOOD DIY HERE!!!
edit #2:
ANOTHER EXCELLENT DIY!
Those are step by step..if you can't do it...
yourself.
Remove those .....
edit #1:
edit #2:
yourself. Thread
mohawkboom
67
Aug 25, 2015 12:28 AM
drhawkinz
May 16, 2015 11:39 AM
BabyLX
Nov 8, 2001 09:25 AM
vistec
Nov 7, 2001 05:53 PM
CivicHX01
Nov 2, 2001 08:49 PM
