DIY - EL Tape Sidemarkers (no hole drilling required)
Old Dec 8, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Many of you have seen the pics of my DIY EL Tape Sidemarkers. If you've been to Oct 5 Chicago Area meet, you've also seen these things in person. Trust me, the pics do not express just how cool these things look at night. Anyways, on to the DIY!
Shopping List.
EL Tape - I bought the EL Tape kits from pcmods.com. They currently have blue, green, and red EL tape. I chose blue because I have blue turn signal bulbs.
PC Power wires and plugs (optional)
I didn’t want to cut the plug off the EL Tape power supply in case it didn’t work. Then I had the option of putting the EL Tape in my PC.
3M Double-Sided Outdoor Tape
I found this in the window insulation section at Home Depot. This stuff is pretty thin and good for outdoor use. You could substitute the indoor equivalent, but I suspect is won’t be UV resistant and turn yellow and curl up and look terrible. Make sure the stuff you buy is for OUTDOOR use.
Double Sided Tape (Foam type)
This is the more common foam based double sided sticky tape. It will be used for keeping the tape in place inside the fender.
12 Volt SPDT Automotive Relays (optional)
If you want your sidemarkers to alternate the on/off with the corner turn signal bulbs, you have to use a SPDT relay. If you don’t care if they alternate or not, wire the power for the sidemarker directly to the corner bulb wires. I ordered the relays from Parts Express.
Other Stuff
Duct Tape, Electrical Tape, Wire Tappers, Cable Ties, Plastic Bag
Step 0
Jack the car up, use jackstands to support the car, remove the front wheels, remove clips holding the inner fenderwell in place, peel back inner fender.
Step 1
Figure out how long you want your sidemarker to be. Mine is approximately 4” long. Now measure out the desired length of you EL Tape sidemarker. Please not that there are two sides to the tape, a white side and a slightly yellowish side. Make sure the white side (illuminating side) is on the outside. Here comes the scary part. BEND the EL tape at this location. The bend may have to be at a slight angle, depending on how high you want the sidemarker to be. It should look like this:
Don’t worry if you mess up the bend, the tape will withstand a couple tries before the EL tape past the bend doesn’t work anymore. If this should happen (or if the tape is damaged later on), you can just cut off the bad part and start over.
Step 2
Clean the EL tape with alcohol (or similar). Cut a piece of double sided tape off slightly longer than the sidemarker length. Stick this on the back side of the EL tape, be sure to put the tape on the yellowish back side. Trim off the excess double sided tape, since the sticky tape is wider than the EL tape.
Step 3
Cut off a 2” length of double sided foam tape. Stick this at the end of the 3M Tape. Trim the width if necessary.
Now you should have something that looks like this:
Step 4 (optional)
Take some black electrical tape, and stick it on the outside of the EL tape that will be inside the fender. This will mask the unused part of the EL tape.
Step 5
Fish the EL Tape between the fender and the door and between the black inner guard thing (inside the fender).
Step 6
Clean the mounting area with alcohol (or similar). Peel off the liners of the double sided tape. CAREFULLY position the EL tape on your fender. Start at the gap between the fender and the door, and press the tape on, working toward the front. Reach between the fender and door to press the foam based double sided tape to the inside of the fender. Everything should look like this:
Step 7
Take your trusty roll of duct tape, and secure the EL tape to the inside of the fender.
Step 8
Wire the Parking/Turn/Ground wires to the SPDT relay and sidemarker as listed below:
30 - Parking Lights (+)
85 - Turn Signal (+)
86 - Parking/Turn Ground (-) AND Sidemarker (-)
87 - No connection
87a - Sidemarker (+)
DIY - Wiring Sidemarkers to blink out of sequence w/ corner turnsignals
Enjoy!
BTW, these things don’t seem to like rain. Water seems to get between the laminations and keeps the EL tape from illuminating. Once it dries out, it works fine again. I may try putting a tiny bit of silicone sealant on the top part of the EL Tape to keep moisture out.
Old Dec 9, 2002
civicvtec1ps's Avatar
Search and Learn
Old Dec 9, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
AWESOME DIY dude!!!!!
Good Job looks really good
Old Dec 9, 2002
Elite's Avatar
Elite is an unknown quantity at this point
You have some pretty nasty dents on the side of the door other than that DIY looks good, Imma do it thanks.
Old Dec 9, 2002
bboysushi's Avatar
bboysushi is an unknown quantity at this point
sweet
too bad I already got (not installed) sidemarkers and they don't offer amber/orange
Bboysushi
Old Dec 9, 2002
Quote
[hr]Originally posted by: Elite
You have some pretty nasty dents on the side of the door other than that DIY looks good, Imma do it thanks. [hr]
Actually that little ding on the pass door is the only dent on the car. Unfortunately it's on the side I did the DIY pictures on. [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Dec 9, 2002
RiceBuRNeR's Avatar
Turbo Member
very origonal
Old Dec 9, 2002
Freak's Avatar
Freak is an unknown quantity at this point
Wow thats a nice job... will that fly as street legal?
Old Dec 9, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Loving it!!!
Old Dec 9, 2002
RedDragon333's Avatar
Great DIY, looks good
Old Apr 4, 2003
FYI, the snow and cold killed the exposed part of the EL Tape. I'm gonna redo them when I get a chance. This time I'll run a thin layer of silicone sealant over the edges. That or find some kind of clear plastic sheath to put them in.
Oh yea, I also think bending the EL Tape cold didn't help either. It led to the tape delaminating. I'll be heating up the tape before I bend it this time.
I'll post updates as they happen.
Old Apr 4, 2003
nme3's Avatar
JDM wannabe
nice!! great diy
Old Apr 4, 2003
Dr5D's Avatar
thats cool! i didnt even know they made light up tape!
Old Apr 4, 2003
GaGu's Avatar
GaGu is an unknown quantity at this point
nice!
Old Apr 4, 2003
ok, I updated the dead link for DIY - Wiring Sidemarkers to blink out of sequence w/ corner turnsignals
lease:
jdh022764
18
Nov 3, 2015 06:44 AM
amrhamed
Sep 21, 2015 02:56 PM
nixyfior
Sep 14, 2015 08:32 PM
