help with a cf hood
Old Nov 13, 2002
Pastor's Avatar
Pastor is an unknown quantity at this point
help with a cf hood
How do you get a c f hood to lock down when closed?
Old Nov 13, 2002
keffin's Avatar
uhhhh...HOOD PINS!
Old Nov 13, 2002
bignutter's Avatar
bignutter is an unknown quantity at this point
Usually hood pins. Some hoods allow you to put your factory latch on too.
Old Nov 13, 2002
RedDragon333's Avatar
Quote
[hr]Originally posted by: bignutter
Usually hood pins. Some hoods allow you to put your factory latch on too.[hr]
Beat me to it, you should be able to tell bny looking at the hood itself how it latches but if were you i would use the latch if possible and hood pins as well they arent expensive and require no drilling in the chasis IMO
Old Nov 13, 2002
Pastor's Avatar
It has a latch, but it won't close all the way.
Old Nov 13, 2002
vtexcivic's Avatar
vtexcivic is an unknown quantity at this point
i had the same problem when i purchased mine the thing you need to do is loosing the bolts on the latch and then move the latch all the way up. tighten the bolts shut your hood. everything will fall in place
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
rnaodm
Sep 21, 2015 12:42 PM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
