some q's on block guards
Old Nov 6, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
here's a picture:
"Get the piece of mind of solid cylinder walls with your high performance engine. Constructed of aircarft aluminum, the block guard slides right into the block sleeve for an easy install."
Does the block guard sit on top of the cylinders or where exactly is it located with regards to the cylinders?
I would like to know if cars come from the factory with a block guard or if only certain cars (i.e. sports cars) come with it.
If someone can show a pic or give a link of the block and where the guard is that would be great
Old Nov 7, 2002
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
Block Guards are used by engine builders around the world. It is made out of aluminum and designed to fit between the block and the floating cylinder walls to strengthen the walls on modified engines. On this product it seems the block guard has drilled holes along the coolant track to allow proper coolant flow as well.
styles234
21
Nov 19, 2019 07:23 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
emiixo
Exterior
Sep 22, 2015 03:53 AM
MichaelLW
Sep 14, 2015 07:15 AM
MamaBear2015
Sep 7, 2015 06:00 PM
