Making the headlights clear!??!
ThE FaMiLy SeDaN
where are you located??? i could help you if you live near tampa.area. i cleared mine my friends and a couple others...
riley
do you have coupe or sedan. the sedans are alot harder and take more pateince.. if you take out the bulbsa but make shure not to touch the halogens. you can stick them in the oven at 175 degrees for 4-5 min. and that will soften the caulk enough to pull apart easier. but the main thing is when you go to put them back together use alot of silicone caulk but look on the side of the tube and make shure it's good for temps up to 140F.
riley
ThE FaMiLy SeDaN
like i said the over is the easiest way cause if you put thme in hot water you'll have to clean off all the water but one thing only put them in at 175 degrees for 4-6 minutes until hot and when youi take them out dont be afiard of them being hott just rip them apart asap becuase the longer it sits on your counter the harder it is to pull apart.. any more ?'s just post.,
riley
riley
usajags84
15
Aug 19, 2015 03:12 AM
civicPRODIGY
Nov 12, 2001 09:32 PM
