Air Condition On&Off
Old Sep 8, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
Don't know what's wrong...It's been a while..but didn't have time to bring it back to the dealer. Just wondering has this ever happen to anyone on here?..
ok...inside my dash my signal light is on for the right light...but dimmer green..
and sometimes i put it on....it doesn't signal...and when the dimmer green is there..
i can't put on my air condition....but when it's gone..i can...and outside...i look at the signal light it's like hyper blinker...anyone know what's wrong.?/?
thanks..
Old Sep 8, 2002
Grey's Avatar
DIY King
It sounds like a short circuit. It might be that the turn signal wire is shorting with the AC wire. It's a big problem. If you have the electrical manual for our cars, then you might be able to hunt down the short, if not then it's best to take it in to the dealer.
It might also be that the ECU (ECM) is retarded and a bad ground or a faulty fuse is to blame. First check all of the connections. Make sure they're tight. Then check the fuses. Take them out and look at them. Replace them with the spares just in case. Try it again and see if the problem is still there. If it is then it's probably a short circuit.
Old Sep 8, 2002
1028CiViC's Avatar
Should i reset the ecu? will this help..
yea..i guess i have to take it back to the dealer...
Old Sep 8, 2002
Grey's Avatar
DIY King
No, resetting the ECU has nothing to do with it.
Old Sep 8, 2002
1028CiViC's Avatar
what about changing the signal light bulb? cause i think the fuse is fu* that's why it's causing this..i just reset my ecu..and it was working fine..but i would wait a few days ..
see if it's still ok if not i am going to bring it back to the dealer.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
amrhamed
Aug 31, 2015 07:47 PM
tylerginevan
Apr 27, 2015 12:29 PM
