What happens when.......?
Old Sep 5, 2002
Weatherman's Avatar
Weatherman is an unknown quantity at this point
What happens when the the dealership over fills your oil past the top hole on the dip stick? It looks like maybe a 1/4 of a qt over........2nd question...What is the prober oil level on the dip stick??? Is it at the top hole or below it or what? thanks in advance for you help!!
Old Sep 5, 2002
ekwc's Avatar
ekwc is an unknown quantity at this point
Look at the top hole on the dipstick that will be the maximum oil level. Making sure check you oil with engine off and parking on a level ground. For more details, look at your civic owner manual[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Sep 5, 2002
Weatherman's Avatar
Ok...So what happens when it's over filled.???...I checked after the engine has been off for a long time so the oil was settled and it was still over the top hole?? Like I said before...it's about a 1/4 qt over...Should I worry about it??
Old Sep 5, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
1/4 quart probably won't hurt. If you get like over a quart then your oil starts to foam up and you don't get good lube.
Old Sep 5, 2002
bignutter's Avatar
bignutter is an unknown quantity at this point
I remember when my sister put so much oil in her car that the oil was spilling into the breather tube and into the intake. That thing smoked like crazy and ran like @ss.
Old Sep 5, 2002
Grey's Avatar
DIY King
Betwean the holes is optimal. If it's over, then the crank shaft will slap the oil as it turns and it will foam up like silverdevil said. Plus the car will be harder to start. Going over will just put strain on the engine and it will be bogged down. You might be okay, but you might lose power while cornering or braking or stepping on the gas. Anything that will make the oil come up higher on one side. Imagine reving to redline and cornering. The oil will suddenly hit the crank case and it'll be like it's hitting a brick wall. I don't know what happens in this situation? I'de have to search for some articles about it...
Old Sep 5, 2002
1955's Avatar
drain the oil
Old Sep 5, 2002
ekwc's Avatar
If I were you I would leave it alone, .25 qt won't hurt. Beside, it is kind of hard to drain .25 qt only. Make sure check your oil level for the next oil change before you leave the dealer[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Sep 5, 2002
Weatherman's Avatar
Thanks for the info everyone...I plan to start doing it myself from now on...plus I'm going to try the
Moble 1....Thanks again
Old Sep 5, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
I saw a kid open his oil fill hole on a Type R and he had an instant oil geyser...was pretty funny, but serious if the oil is hot and you burn yourself..keep it between the 2 holes!!
2Hottie
Old Sep 5, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
take it back to the dealer but you should be fine!!!
