Question for those with Turbos
Old Sep 2, 2002
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
This question is only for those that currently have a turbo on their Civic: what boost are you running, which turbo did you use (t3, t3/4, etc), where did you get a manifold, and what fuel system upgrades did you make? I am putting together a custom kit, and wanted some more advice from those that have done it.
Old Sep 2, 2002
enzymes's Avatar
enzymes is an unknown quantity at this point
The only numbers I've heard are like 5psi, which I know isn't much, but I think they were being really safe about it.
Old Sep 3, 2002
Ichiban's Avatar
Ichiban is an unknown quantity at this point
honda tuning says that the current headless fuel system can only handle like 40 hp increase. That includes like turbos and nitrous. I am trying to see how much it would be to put a return line from the engine to the tank and not just in the tank.
Old Sep 3, 2002
First to spool
But if you replace the pump, line, and injectors, it can handle a lot more than that. Lancer Revolutions (not the evolution, it's a 2 door non rally version) have been running a returnless fuel system for the last two years, and they can handle a lot of hp increase if you just change those three things and run a fuel computer.
I already know I'm running larger injectors, with two additional injectors before the throttle body controlled by a Haltech with its own MAP sensor for boost, that way the stock computer handles all pre-boost and then once it hits boost, the haltech unit and it's two injectors come in and increase the fuel to handle the boost. This maintains the drivability and fuel economy while I'm not in boost (before 3,500 rpms we estimated) and then it's still safe while in full boost (after 4,500 rpms we think). We're thinking this setup should be more than adequate, but I wanted to see what everyone else was doing to compare drivability and cost, the Haltech is not a cheap computer.
Old Sep 3, 2002
tekgnosis's Avatar
Ask me about your mom.
Hey d00d
I don't currently have a turbo, but I'm in the midst of buying one.
My plan is to go at 4psi until I can upgrade. I think 4/5 is the general 'safe' marker for people like me, who haven't upgraded ANYTHING.
If you upgrade your fuel lines, though, you can run probably up to about 8/9 being 'safe'. If you do some engine internals work, you can go as high as you like! Keep in mind, you can only squeeze so much out of a poor little 1.7L tho [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Oh, and do you have an intercooler?
Lemme try this again:
I'm doing this -
4psi with just plumbing + turbo (no intercooler or anything)
6psi with intercooler (not exactly a whole lot safer, but still...)
10 psi with upgraded fuel lines, fuel computer (the apex one is dang nice), turbo timer (not needed, but nice to have), and probably a bit of internal work.
I'll be happy with just the 4psi boost ( roughly 32HP ), so I can't imagine going up even higher!!! Cant wait!
Keep us posted with your results, though, so we can all live vicariously through you [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Cheers
Old Sep 3, 2002
First to spool
The fuel system I will be using (Haltech with 2 extra injectors) can handle flow rates consistent with up to 30 psi, the only thing limiting me is the engine itself. I will have an intercooler, and will be doing internals as soon as JE gets off their *** and brings the prototype pistons to production.
Old Sep 3, 2002
tekgnosis's Avatar
Oh, in that case, I'd try it out at 8...and if it works good for a while, keep on raising the bar!
no pun intended [IMG]i/expressions/face-icon-small-wink.gif[/IMG] hehehe
I think the most I would push it, would be 1 BAR, though. But...I'm paranoid, and would probably run 10.
Don't listen to me, I'm just rambling.
Let us/me know how it goes. I wanna go down the custom route for my civic...
Which turbo are you using? the T3? The T4 seems too big IMO.
Old Sep 3, 2002
First to spool
T3. Was planning on starting around 5, hitting 7-8 soon after, maxing out at 10 for race until I build the motor.
Old Sep 3, 2002
tekgnosis's Avatar
Sounds good!
Take some pics and keep me/us posted!
-HondaFTW-
Aug 30, 2015 10:38 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
