DIY Caliper painting??????
Old Aug 30, 2002
pounds's Avatar
pounds is an unknown quantity at this point
anyone have one of these??
Old Aug 30, 2002
slikor's Avatar
slikor is an unknown quantity at this point
here ya go man, i found a couple threads on this topic, they both have some details on what to do, and info about the paints to use, etc:
Thread: What to use to Paint Brake Calipers? (edited)
Thread: brake calipers
it essentially involves removing the 2 bolts that hold the calipers on the knuckle assembly, suspending them, and covering everything else in the wheel well and spraypainting (you can also get paint that you apply with a brush) the calipers.
Old Aug 30, 2002
Mbow's Avatar
I would clean the calipers with some heavy duty degreaser before painting.
Old Aug 30, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Quote
[hr]Originally posted by: Mbow
I would clean the calipers with some heavy duty degreaser before painting.[hr]
Mos' Def!
Old Aug 30, 2002
Grey's Avatar
DIY King
You know how hard those are to clean! The best thing in the world for cleaning those is this... Take the caliper off of the hub. Then mix some Lye (Drain Cleaner) and water in a bucket. Then just place the caliper in the solution and let it soak. Take out the little hardware so that it doesn't get messed up. Take out the copper thingies and take out any small screws. Let it soak for about an hour. Remove it and you're going to see some bling bling. Use rubber gloves and safety glasses too. After doing that I would just clearcoat the sucker. I might do a DIY later. If I find the time. Maybe Sulfuric Acid will do the trick as well? I have to experiment.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
carid
Sep 28, 2015 10:13 AM
Junquito89
Sep 27, 2015 10:22 PM
speedlever
Sep 24, 2015 07:18 PM
