Tips on installing OEM Spoiler
Old Aug 23, 2002
MikeCL1041's Avatar
MikeCL1041 is an unknown quantity at this point
I recently ordered my OEM spoiler and should be getting it any day now. Does anyone have any tips on how to install it, I wanna make sureto do a good job. Thanks.
Old Aug 23, 2002
xian's Avatar
Honda > Nissan
xian is on a distinguished road
Measure 4 times, cut once. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Make sure you put the template on the hood correctly.
I've heard of stories where people didn't put the template down properly, thus drilling out holes on the wrong side. i.e. extra hole for wiring of brake light on the wrong side. [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Good luck...
Old Aug 23, 2002
MikeCL1041's Avatar
Thanks, I don't think I'm going to put it on the hood though , just kidding. Thanks.
Old Aug 23, 2002
xian's Avatar
Honda > Nissan
HAHAHAHA, I didn't even realize I put down "hood". Well, you knew what I meant.
Old Aug 23, 2002
Royando's Avatar
Royando is an unknown quantity at this point
have a friend help
Old Aug 23, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
look under your trunk lid...there are already indents under there so you know where to drill.
Old Aug 23, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Coupe Instructions
Sedan Instructions
Have fun!
Old Aug 23, 2002
johnride's Avatar
johnride is an unknown quantity at this point
It is easy to do I installed mine my self just take your time with it.
Old Aug 25, 2002
Kapriccio's Avatar
Kapriccio is an unknown quantity at this point
I just installed mine last week, and if it's the OEM, you'll notice that there are two marks on the inside of your trunk. You'll just have tu use the included template for the light hole on the drivers side. Just measure to double check, drill....and pray it fits. Good Luck. Luckily, mine matched perfectly! Ugly feeling drilling holes in you car though!
Old Aug 25, 2002
2K2RallyeRed's Avatar
2K2RallyeRed is an unknown quantity at this point
i installed an aftermarket oem a few months ago, i drilled the holes on top perfectly and everything but after i was all done i realized that on the inside there were spots for where to drill, i was quite mad at myself, but whatever
Old Aug 25, 2002
Mbow's Avatar
I installed my spoiler as well. I got a replica and saved myselft $175 and you would never know the difference.
Anyhow, to my knowledge, all hondas have the dimples in the truck lids for spoilers. You will see them when you take a look, 2 on each side. Use a center punch to put a little dimple in the center of each spot. Then, use a 3mm drill bit or something small to get the holes started. Then, go up to the size that the spoiler requires. I used the little rubber gasket thing to drill the hole for the wiring. Also, use touch up paint on the holes before putting the spoiler on. I also put some silicone in the holes before mounting the spoiler.
Overall, it's a very simple install. It's just a wee-bit scary when you go to drill that first hole.
Old Oct 4, 2002
fraga's Avatar
Wicked Moderatuh
Just bought an OEM Spoiler in market place. THe guy took it off his car. Anywho, I have no template to drill. Where can I find a template. Help, I need help people.
Old Oct 7, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Quote
[hr]Originally posted by: fraga
Just bought an OEM Spoiler in market place. THe guy took it off his car. Anywho, I have no template to drill. Where can I find a template. Help, I need help people.[hr]
No need for a template fraga. Just follow what Mbow said. Thats basically what I did as well, minus the silicone. Find the 4 dimples inside the trunk. Put some masking tape or some of that blue carpenter's(?) tape on the outside of the trunk (so the metal shavings dont fall on/scratch your paint) and drill away. Use some touch up paint and anything else you 'need' to protect the hole.
HTH
-Kre
mugenca
Apr 16, 2015 12:15 AM
aZnVoYCe
Dec 7, 2001 12:41 AM
TropiKalCiviC
Nov 15, 2001 12:08 PM
aZnVoYCe
Nov 7, 2001 05:54 PM
blueracer
Sep 5, 2001 11:23 PM
