boost controller question
Old Aug 14, 2002
DC5@EM2's Avatar
DC5@EM2 is an unknown quantity at this point
Ok, I'm kinda doing my homework on turbos and their parts. Ok so this is what I took boost controllers for. You can basically control boost levels with them, so if you are not running you car that hard you can lower the boost to like 7-8 psi if your normal boost level is like 9-10 psi. And then you can increase it to 11 and up for racing purposes. Is that correct? And also, when you increase or decrease the boost levels with them, does that control your A/F mixture too? Cause I was thinking that if it doesn't, couldnt that be really bad cause that would cause you to run either really rich or really lean? Im kinda confused on this whole boost controller issue. If anyone has any info, he a brother out. Later.
Old Aug 14, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
a boost controller generally works WITH (or in addition to) an external wastegate, or i guess some internal wastegates......the boost controller tells the wastegate how much boost to "bypass" past the turbo, and just shoot down the downpipe instead
depending on the boost controller ( i know the apexi afc-r) some DO change the A/F maps accordingly.....
mark
Old Aug 14, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
in additional, not all turbos run at an average boost of 9-10 psi... it all depends on the car and the turbo. make sure u learn this before u put on a turbo that is either too big or inefficient for ur car.
Old Aug 14, 2002
DC5@EM2's Avatar
yeah i know, i was just giving an example of numbers. So the apex afc-r does change the A/F maps. Ill probably get that one then if Im gonna do this. Thanks.
viper775
Dec 9, 2001 10:52 PM
