Zex Products???
Old Jul 12, 2002
ilv4nos's Avatar
ilv4nos is an unknown quantity at this point
Zex Products???
Got a couple questions for all you techs out there about the Zex Nos system. 1. What shot should i go with a 50, 60, or 75? 2. ok, now i know that the zex system has that electronic sensor that detects the throttle body being open thus shotting the nos if the system is engaged, does the sensor time the nos in between bursts? because it would constantly feed the motor unless you disarmed it, i want one shot of NOS right in 1st gear on my AT getting me into the top end and the other in 4th giving me more top end, my question is how much time do i need between shots and if the zex is so smart shouldn't it time between bursts. Thank you for all ur help.
My Civic
Old Jul 12, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
hey homie if you are going to use nitrous you better STUDY up on it because we cant use the ZX kit and dont use anything over 60 unless you have i/h/e and interenals (sp) done to your civic STUDY nitrous and search bofore you post
Old Jul 12, 2002
ilv4nos's Avatar
homi, thats the whole point of my questions.....uhh to learn...research? your comments and opinions determine my decision and give me knowledge on which product to use...now NX system sucks and i will not install it...zex is safer to me and more computerized. Thank you
Old Jul 12, 2002
ilv4nos's Avatar
oh and homie NOS can be used on a factory motor any factory motor, internal work helps and you can use a bigger shot. than what i am calling for.
Old Jul 12, 2002
sadboy916's Avatar
(yawn) okay man i am not trying to stand in your way but this topic has been touched alot and a search will most likely answer most of your nitrous questions but STUDY nitrous or you might end up killing yourself or someone else
DONT BE A F&F RACER
Old Jul 12, 2002
ilv4nos's Avatar
just asking about it man....and lol...f&f racer funny.....we love our country roads man we race alot....have a good day
Old Jul 12, 2002
Numinous001's Avatar
Numinous001 is an unknown quantity at this point
Quote
[hr]Originally posted by: ilv4nos
homi, thats the whole point of my questions.....uhh to learn...research? your comments and opinions determine my decision and give me knowledge on which product to use...now NX system sucks and i will not install it...zex is safer to me and more computerized. Thank you[hr]
Why would you consider a NX kit any less safe? It has a Wide Open Throttle switch and a master arm switch. Do the electronics make it safer? And if they do how so? I know theres systems out there that only let the nitrous spray during a certain RPM range.. that along with a WOT switch would probably be the safest setup.
Also, from everything I've been reading so far it's not too good of an idea to use nitrous in first gear. I'm not really sure what you mean by a timed shot.. because from everything I've seen the nitrou system just sprays when all your conditions are met(ie. WOT, or possibly WOT and certain RPM range)
-Numinous
Old Jul 12, 2002
ilv4nos's Avatar
NX nitrous=to much crap to hook up in my eyes plus i like zex alot, i am looking for suggestions anyway....i do want zex though and plus i live in IN no emissions lol...
Old Jul 12, 2002
delacampos's Avatar
delacampos is an unknown quantity at this point
zex will not work on our cars. besides, it just does not yield the results nx kits do. zex computerized? have you ever seen the inside of the zex purple box? there's nothing computerized about it.
Old Jul 12, 2002
sadboy916's Avatar
Quote
[hr]Originally posted by: delacampos
zex will not work on our cars. besides, it just does not yield the results nx kits do. zex computerized? have you ever seen the inside of the zex purple box? there's nothing computerized about it.[hr]
lol thats what i have been trying to tell this kid . Just trying to save him 600 bucks and a engine
Old Jul 12, 2002
ilv4nos's Avatar
ok....i know the systems aren't different i realize that duh...i know that zex and NX are the same exact thing except on has two solenoids and the other just has the box...same controlers whatever...i am talking about the engaging part...."For your performance car, Zex™ has designed the ultimate "Smart" Nitrous System. Depending on the application, the additional 55-125 horsepower it provides will have you tearing up your competition. The ZEX™ Nitrous System, using our patented technology, uses bottle pressure to regulate the nitrous to fuel ratio. This ensures the greatest level of engine safety.
Once armed, the kit is activated at wide-open throttle by an electronic sensor that "learns" the voltage curve of your TPS sensor. This design ensures your nitrous is engaged at the perfect throttle point, every time. The design of the ZEX™ Nitrous System makes it the simplest, safest, and easiest to install kit on the market."
the kit is activated.....does it deactivate automatically or do i have to disarm it my self....the wide open throttle occurs for obviously for a long time....i am wide open to 120 mph...now...my question in general does the thing send a constant flow of nos or does it shoot in bursts....
Old Jul 12, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
The zex kit has a soft touch switch that you put under ur gas pedal.. when u floor it it sprays nitrous when you left off the gas it stops. Stop even considering zex we cant use it for our car we have a returnless fuel system. This topic has be beaten todeth next time search u noob! Also the zex kit dose not provide nearly as much power as the nx, the nx has bigger solinoids which allow it to pump more nitrous in quicker. So to answer your question in a manner that is painfully obvious:
ZEX=NO
NX= YES
Old Jul 12, 2002
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
Quote
[hr]Originally posted by: PseudoChrist
ZEX=NO
NX= YES[hr]
Pseudochrist I agree with most of your reply but when i had ZEX in my old car there was not a switch behind the gas pedal... How ZEX know when it's it's WOT is that the ZEX box is hooked up to the fuel pressure regulator and throttle positioning sensor.... Once you floor it. the throttle position sensor know it's at WOT throttle so it activate the nitrous... If you have the switch "armed" and keep flooring it it will keep squeezing nitrous until the switch has been turned off or let off the gas some so it's not at WOT...
Old Jul 12, 2002
neocivicracer's Avatar
neocivicracer is an unknown quantity at this point
i know one of the two owners of ZEX woo hoo
Old Jul 12, 2002
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
besides i've heard that if you use nitrous in 1st gear your manifold can blow up...... it's on another thread on this site.........
Old Jan 8, 2004
02civic's Avatar
Need....More....Mods
02civic is an unknown quantity at this point
had to dig this up cause i'm amazed at the lack of knowlegde from 2 years ago......i'm sure all you guys have learned alot since then so i'm not making fun of you...but wow. calling someone a newb than proceeding to tell him incorrect info
Old Jan 8, 2004
tronics's Avatar
tronics is an unknown quantity at this point
why must everyone jump on him for just asking a ? but anyways why cant we use zex, i have it installed on my car, and it works just fine
Old Jan 8, 2004
mxcivic's Avatar
mxcivic is an unknown quantity at this point
i have the wet ZEX kit running in my auto, i use a 65 shoot, already run like 6 bottles and there is no problem YET lol, for me these kit is great.....
Old Jan 8, 2004
NEWARK-aveP-NJ's Avatar
NEWARK-aveP-NJ is an unknown quantity at this point
so did I run a wet kit.. you cant use a dry kit, but wet aint no problem
Old Jan 9, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
all that was talked about in this thread was Zex and NX...now I don't want to sound like a f&f ricer, but what about NOS? I actually have read up a lot about nitrous use, and I plan on (sometime) doing a wet kit. But what brand? From what I've researched, NOS seems to be the most reliable and with the best technology in solenoids and that sort of stuff.
Old Jan 9, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
I've gone through many bottles on my NX kit....just make sure you buy
a bottle heater, n2o pressure gauge and guel pressure gauge.
Keep you running on the safe side.
Old Feb 16, 2004
ziggyboo84's Avatar
ziggyboo84 is an unknown quantity at this point
ok i am planning on getting a zex wet kit so what is it now i read up that you cannot use zex on our cars but then i saw aobut 20 other people on here that have the zex kit!!! so can you use it or not????? I dont want to spend $550 for no reason!!!
Tyler93
Detailing
Oct 24, 2015 09:48 PM
carid
Sep 28, 2015 10:13 AM
Jrosa
Sep 14, 2015 08:24 PM
