My headlights stopped working ???
Old Jun 26, 2002
errorr's Avatar
errorr is an unknown quantity at this point
i checked the under hood headlight fuses and they were fine the 2 15 amp fuses. When i turn the headlights on nothing happens. And when i change it to brights the bright symbol doesnt show up. What the hell is going on????
Old Jun 26, 2002
HondaCoupe's Avatar
HondaCoupe is an unknown quantity at this point
do your parking lights some on and your directionals work?
Old Jun 26, 2002
errorr's Avatar
yea man i was trying to run a power wire through the passenger side u think i may have cut a wire or somthing i was using a clothes hanger??? im prolly gonna take it to honda tomorrow everything xcept for the headlights work??
Old Jun 26, 2002
HondaCoupe's Avatar
if its under warrenty bring it to honda, or pull the headlights and see if the filiment in them are blown...if they are run somewhere that sells headlight bulbs and ask them for some H4's
Old Jun 26, 2002
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
I would just take it to the dealer...I wouldn't screw around with the electronics too much
Old Jun 26, 2002
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
Yeah man, if your high-beam light doesn't come on, it's not the bulbs, and I'd take it to the dealer. They'd be able to fix it really easy. What were you using a clothes hanger for???
Old Jun 26, 2002
errorr's Avatar
i was trying to pull a power wire through the rubber gromet for my stereo. and neither the lows or the birghts work.
Old Jul 22, 2002
jodave's Avatar
jodave is an unknown quantity at this point
I just got back from the dealer and I have to go back again. My low beams just stopped working the other night. High beams worked fine. Bulbs were good, fuses good...dealer traced it back to a burnt switch and wiring cause by a faulty alarm installation. Anyone want to buy a Viper alarm, this things coming out soon. (Please note: I did not install the alarm myself, a 'professional' did!)
Old Jul 30, 2002
BlueBullet's Avatar
BlueBullet is an unknown quantity at this point
sounds like a burnt switch....if the bright light doesn't even come on then the car doesn't know you are putting the light on...good luck at the factory dude
Old Aug 1, 2002
civiccowboy's Avatar
civiccowboy will become famous soon enough
Do you have aftermarket headlight bulbs? My headlights went out all at once too, and I was like WTF? I checked all the fuses and they were OK. Then I checked the bulbs, they were both blown at the same time! Check your bulbs!! I doubt you did anyhting with the clothes hanger. It would blow a fuse before doing any other damage and you would have had to have the headlights on. Besides, we all know how tough the covering is on wiring. You can barely cut it with a knife.
ORskier
May 3, 2015 12:54 PM
shaejb15
Apr 26, 2015 07:44 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CivicLX2001
Nov 16, 2001 06:33 PM
