Don't be a jerk and just help please
Well... I cleared my headlights and blackhoused them two weeks ago. It was fine for the past two weeks, even through the rain..until i washed my car, Then finally my worst fear had come true...
My headlights fogged up!..
..can somebody give me any helpful advice on what to do??
thanks
My headlights fogged up!..thanks
You could look around the seal of the light and see if you can spot where the moisture is getting inside and just put some more silicone it that spot. You could just run another bead of silicone around the outside of the seal. It would probably be best to pull them apart and redo the seal. I know I put so much silicone on mine that when I pressed them together it was squeezing out everywhere. It's easy to trim away though.
Take the light off, use a blow drier and blow air through the headlight bulb hole till condensation is gone, reseal! That is it!!
THanks for all your help peoples
..Im going to reseal this weekend..One more question though, What would be better...Taking my headlights apart(again:cry[IMG]i/expressions/face-icon-small-wink.gif[/IMG] and Cleaning all the silicone out then reseal it with a whole lot of silicone...or just not take it apart..blow dry it then jus put silicone over the outside..???
thanks guys[IMG]i/expressions/beer_yum.gif[/IMG]
Wild Cranker
427
Jan 28, 2016 06:49 PM
Ninetyatecivic
May 9, 2015 07:48 PM
cchance85
May 9, 2015 11:54 AM
pheaton
May 4, 2015 08:26 PM
