to antidote or whoever else can solve sqeaky springs
Old Apr 27, 2002
Robi's Avatar
Robi is an unknown quantity at this point
Hey i saw when i searched that you were making your springs stop squeaking by using wd40. I have goldlines and i am having the same exact problem in the same exact wheel, front right. I went back to the shop where i got it installed and the guy said i need to replace my bushings, but im thinking ill try your method first, i just dont know exactly where to spray the wd40, and did you find any other better lubricants, thanks.
Old Apr 27, 2002
pinkytoe's Avatar
pinkytoe is an unknown quantity at this point
usually its the top os the spring thats actually squeaking- GREASE the top pearch- not WD- use either bearing grease or antisize- something thick- squeak anilated
Old Apr 27, 2002
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
Do a search first next time. Hey yea, I had the same problem. Go to your local autoshop store and get the spray can of white lithuim grease. You can get the tube form too but it's up to you... I've used both and they work the same- spray is just easier. Anyway, jack up the side that makes the noise (when you turn your wheel, right?) and spray or apply the grease to where the top of the spring meets the perch or housing. That should be it, I sprayed the bottom, too, only because that was another part where metal was touching metal. Hope that helps.
~1~
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
senicalj4579
Oct 2, 2015 10:03 AM
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
TheRiddicles
Sep 21, 2015 01:28 AM
