Civic died and turns but wont start?
Old 10-26-2010
wetpinkpants's Avatar
wetpinkpants is on a distinguished road
I have a 2001 Honda civic lx when I was driving the car just died try to restart and it just turns over . Like its not getting fire or out of time the camshaft is turing so I dont think its the timing belt. I need help? Thanks
wetpinkpants is offline
Old 10-26-2010
breathingsulfer's Avatar
breathingsulfer is an unknown quantity at this point
Re: Civic died and turns but wont start?
sounds like could be a fuel pump problem
breathingsulfer is offline
Old 10-26-2010
sl33pyriceboi's Avatar
yup. thats it right there.
could also be ur sparkplugs are toast. but all 4 dieing is pretty rare
sl33pyriceboi is offline
Old 10-26-2010
Low and slow!
02civicsi02's Avatar
Ya it could be the fuel pump. To check the 3 major things like air, fuel, and spark. To check the air real good take off the intake and stick your hand over the throttle body and try and crank the car and you can tell that its getting air or not but doubt it will be this. To check spark you need to take out one coil pack and the spark plug out also, then stick the spark plug in the coil pack with it still hooked up and place it on the valve cover some where safe and then try and crank the car and see if it has spark. Check all of them like that. To check fuel you can either do it from the back seat where the fuel pump is located or the fuel rail. To do it with the fuel rail just take off the fuel line from the fuel rail and stick the hose into a container and turn the key to on and see if any fuel comes out, the other way is from the back seat. Take off the bottom part of the back seat and take off the top fuel line hose and stick another hose on it that runs to a container and turn the key to on, if fuel comes out then you are good if not then your fuel pump is out.
02civicsi02 is offline
Old 10-26-2010
I will test that what about the crankshaft sensor?
Old 10-26-2010
lazlong's Avatar
Turn the ignition to ON (II), not START (III) and listen for the fuel pump. It'll make a humming sound. No humming= bad fuel pump
lazlong is offline
Old 10-27-2010
I can hear the fuel pump hum but when I pulled the little hose on the fuel rail I dont see any fuel on both ends of the fuel rail
Old 10-27-2010
Low and slow!
You need to put that hose in a container and turn the key to on so that the fuel pump will kick in and push fuel that way and fuel should go in the container.
Old 10-27-2010
Mad Dog Tannen's Avatar
The easiest thing to do is just to throw that car away and buy a new one. lol
Mad Dog Tannen is offline
Old 10-27-2010
eyeheartvtec's Avatar
eyeheartvtec is on a distinguished road
could also be your distributor. make sure you're getting electrical feedback from it.
eyeheartvtec is offline
Old 10-27-2010
lazlong's Avatar
There's no distributor in a 2001 civic.
lazlong is offline
Old 10-27-2010
When I checked at the fuel rail I had the key turned to kick the fuel pump on.
Old 10-27-2010
Low and slow!
Ok so if you did that and no fuel came out then its either your fuel pump or fuel filter.
Old 10-27-2010
i LOL when i read ur reply. HHAHAHAaa
Old 10-27-2010
woops..
Old 10-27-2010
Low and slow!
woops..
Ya the 01 up civics have coil packs.
Old 10-27-2010
I got spark at the plugs and the fuel pump hums like it should but I dont see any fuel at the fuel rail. Can a pump still be bad if it hums? or crankshaft sensor cause it or is it good because their is spark?
Old 10-28-2010
lazlong's Avatar
Probably your fuel filter then. It's in the tank, you can access it underneath the back seat.
lazlong is offline
Old 10-28-2010
Low and slow!
It is possible that the fuel pump kicks in but cant send any fuel but that is rare. The fuel filter is located right on top of the fuel pump assembly and it could be clogged up not letting fuel through. Make sure you get the right thing at auto parts stores. My SI has the same thing as you and they where trying to give me the wrong thing. The auto stores where trying to give me the cylinder fuel filters that go in the engine bay when thats no where near what we need.
Just get the rear seat off and take the top hose of the fuel filter and put a hose on the filter and run that hose to a container and then turn the key to on and see if any fuel comes out there.
civic_gt
04-19-2015 08:15 AM
twtron
04-17-2015 12:09 AM
McD
04-16-2015 10:46 AM
SSMatey
04-13-2015 06:09 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: Civic died and turns but wont start?
