2001 Honda civc new head gasket valves seem loud?
Old Aug 15, 2010
wetpinkpants's Avatar
wetpinkpants is on a distinguished road
Its a 2001 honda civic LX I put a new head gasket and had the head planned. I adjusted the valves and I went 0.008 for the intake and a 10 for the exhaust. and I put back 5w20 oil. but the valves seem lound to me more than before and before does it hurt anything? I always used 5w30 I could use any help I can Thanks
Old Aug 15, 2010
Mad Dog Tannen's Avatar
Re: 2001 Honda civc new head gasket valves seem loud?
Loose is better than tight when it comes to valves but I would go throught them again. If they are noticeably loud. I just did mine on my B16 it was .006-.007 intake and .007-.008 exaust. Better to double check and readjust. If you have never adjusted valves or used a feeler guage before then get someone to help you. You need to get it them tight enough to where they just start to pull on the feeler guage. If you can remove the guage without resistance then they are too loose. Does that make sense?
Old Aug 15, 2010
02civicsi02's Avatar
Low and slow!
Did you do the valve adjustment correctly. Meaning started with cylinder 1 at TDC then rotate the crank 180 degrees and then cylinder 3 at TDC, rotate the crank 180 degrees and then cylinder 4 at TDC, rotate the crank again 180 degrees and finally cylinder 2 at TDC.
Old Aug 15, 2010
I understand the feeler with the slight drag. but when it says .006 .008 is it better to do it at .006 or where? I did do the 1 at TDC then rotate the crank 180 degrees and then cylinder 3 at TDC, rotate the crank 180 degrees and then cylinder 4 at TDC, rotate the crank again 180 degrees and finally cylinder 2 at TDC. tonight I will recheck them. thanks for helping
Old Aug 15, 2010
Just try and get it in between.
LionSpratt
Jan 29, 2017 11:07 PM
hokiedad4
Apr 30, 2015 07:18 AM
jessicakaybby
Apr 20, 2015 12:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
Bartkat
20
Feb 19, 2002 01:29 PM
