ZC engine valve lash
Old Aug 1, 2010
zccivic's Avatar
zccivic is an unknown quantity at this point
does anybody know what the valve lash on a ZC JDM engine is suposed to be? also, where do i check it? at the cam or the adjuster?
Old Aug 1, 2010
Re: ZC engine valve lash
usually you check at the valve adjuster, theres a few diys floating around. you can only adjust a certain set of valves at a time depending on which position the crank is in. and adjustment values are on a sticker under the hood.
Old Aug 1, 2010
zccivic's Avatar
it is in a 91 civic that originaly came with a d series 1.5 liter, somebody b4 me bought an imported ZC engine from japan and dropped it in, i drove it and it is fast, the guy b4 me did 14 seconds in the 1/4 mile, in other words the sticker under the hood is for a diff engine, when the engine is idling it has more than the normal honda valve clatter so i want to tighten it up a bit,maybe eek another few hp at the same time
Old Aug 8, 2010
zccivic's Avatar
*BUMP* i really need the answer for this
Supramk3
May 11, 2015 07:55 PM
crowtoo
May 11, 2015 06:50 PM
Chronic_issues
May 8, 2015 05:40 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
CapYoda
Nov 11, 2001 05:17 PM
