Engine wash: Now power fluctuation.
Old Jun 12, 2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
So I made sure the engine was cold, covered the intake, degreased and hosed it all down. Now my engine is fluctuating as if it's running on 3 and then 4 cylinders, no check engine light. I had this problem on my trip to Sacramento in the winter. I would go through the fog and the car would loose power. Then out of the fog it would regain power. Now you would guess it is an exposed electrical connector, but how do I go about troubleshooting that? The only thing I can think of is to spray each connector with a water bottle.
Is there anything else that can cause this? I've been running STP fuel cleaner through it, so maybe it's a fuel injector that's clogging and unclogging? (doubtful)
Old Jun 12, 2010
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
Re: Engine wash: Now power fluctuation.
sounds like u have an open somewhere spray water on the wires, connections ect. n look for any arcing
Old Jun 12, 2010
How do I check for arcing? Car in the garage with lights off? I keep hearing this like bearing type sound when I depress the gas, but I wonder if it's electrical because there's nothing wrong with my transmission bearings.
My car works better now that it's dry, but when I make a left hand turn, it hiccups like it wants to die or misses a spark. Probably the connections under the intake... I'll keep troubleshooting.
Old Jun 12, 2010
lowlife9's Avatar
did you cover the alternator ???
Old Jun 13, 2010
ubnpast's Avatar
ubnpast is on a distinguished road
pull the wires and use an air compressor to blow out any water that may be sitting on top of the spark plugs, this is what happens to me most of the time.
Old Jun 13, 2010
BlueEM2's Avatar
Whachya lookin at?
No water should be getting in around the spark plugs. The top of the coil should be sealed well enough to keep water out, unless your going absolutely crazy with water on the valve cover. Worth a shot checking though.
Old Jun 13, 2010
The previous problem is gone but now it feels like weak spark. Engine runs smooth though. I just love troubleshooting electrical...
And yeah I did spray the alternator.
Old Jun 13, 2010
Nah, nothing in there.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
cloudguy
Apr 28, 2015 05:02 AM
Dmitri
123
Oct 13, 2005 08:01 PM
silvervtec01
Dec 9, 2001 08:50 PM
supercivic01
South
Nov 30, 2001 11:27 AM
