Ctrl alt cat delete
Old Jan 14, 2010
6thgencivic908's Avatar
6thgencivic908 is an unknown quantity at this point
Ctrl alt cat delete
good news everyone i have found a way to trick you computer effectivly into not throwing a cel with a cat delete! yes some of you may already know this, but awhile back i asked people on this forum how i could get rid of the cel and i got no real asnwers. so here it is
http://forums.evolutionm.net/evo-how...ouler-how.html
Old Jan 14, 2010
Re: Ctrl alt cat delete
good info
Old Jan 14, 2010
ronaldo9's Avatar
This is old news and yes it works but you'll be running a bit leaner as well fyi.
Old Jan 14, 2010
lowlife9's Avatar
unfortunately that trick doesn't work on all models like my 2004 dx being that the cat is in the header and the alternater is in the way but there are a couple companies that make angled ones like blox,megan,and weapon r. i use the megan style it was 24 bucks and short enough to install without removing the header.
http://www.robearracing.com/pd-megan...or-cel-fix.cfm
Old Jan 14, 2010
ronaldo9's Avatar
Yes you can get angled ones for the lx/dx owners.
Old Jan 14, 2010
lowlife9's Avatar
so how does it make the car run leaner ???
Old Jan 14, 2010
i have no idea. i thought the secondary cat sensor was only for emissions info (doesnt affect engine like primary).
Old Jan 14, 2010
ronaldo9's Avatar
I don't know im speculating from the lack of back pressure that the cat provides I saw this on my wideband. I ran two setups at one point one with cat and one w/o cat and had to change the tune bc when put the cat back on the car was way too rich to run w/o throwing a code and I was throwing lean codes after taking the cat off. I was seeing 13's high 12's on the wideband at WOT w/o the cat and with the cat same tune i was seeing 11's and low 12's.
Old Jan 14, 2010
i dont really think it can make the car run leaner, yes it tells the car whether it is running too lean or too rich, but all you are doing is giving it a smaller amount of exhaust to take the readings from, and in theory somehow it mixes with some more air or something b4 it gets burned by the thermo couple (thats all an o2 sensor is, it heats up and sends electrical current to the ecu based on how hot it gets or something). You can also take the wire that sends the voltage back to the ecu and put a resistor in that wire. you want to achieve a .45v or less to not throw a cel. now in that cae you could be running too rich all the time and that would not be the best, but it can be done. also as most everyone knows you can get o2 simulators for around 80 bucks. now i dont know too much on how they work, but instead of giving a constant .45v it will vary.
Old Jan 20, 2010
Running Riot's Avatar
^Warranty voider
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
....take the bulb out. no more cel. duh.
Old Jan 20, 2010
ronaldo9's Avatar
I'm not saying the secondary 02 is causing the car to run leaner but there is difference in way the car drives running with and without the cat.
Old Jan 20, 2010
^Warranty voider
id have to disagree with you on this one unless what you meant was the car runs smoother, quicker cooler and more efficiently. the secondary o2 is just a signal to the ecu that the cat is working.
Old Jan 20, 2010
^Warranty voider
thats the job of the o2.
Old Jan 20, 2010
ronaldo9's Avatar
I'll have to prove it with the wideband I guess bc I'm not making **** up the tune changed quite a bit just by putting the stock exhaust back on with the cat.
Old Jan 20, 2010
well the cat does change how fast the exhaust flows, maybe thats why. if you look inside, its almost not possible to think air would go thru all that mesh. you have turbo right? the stock exhaust is a huge limiting factor, the pipe diameter is too small so im sure its an airflow issue affecting the sensor readings.
Old Jan 21, 2010
^Warranty voider
that also bring in delta flow vs. back pressure though right?
Luluharp
Sep 27, 2015 11:56 AM
rezsst
Sep 26, 2015 07:04 PM
beanhead
Sep 24, 2015 12:04 PM
blizza
Sep 20, 2015 04:09 PM
Hollywoodsnake
Sep 20, 2015 12:58 PM
