DIY Internal USB Charging Wire
Old Oct 11, 2009
Juancho007's Avatar
Juancho007 is an unknown quantity at this point
Hey everyone, does anybody have any experience installing a permanent-internal usb charging wire for something like a GPS? I have a windshield-mountable Tom Tom which has a good old usb car charger but I'd like to hook up a permanent internal wire for it.
Where should I get supplies? Any words of caution (i.e. fuses, voltage, etc)?
Thanks!
Old Oct 11, 2009
sl33pyriceboi's Avatar
Re: DIY Internal USB Charging Wire
holy crap a 2001 member. someone help this man.
Old Oct 12, 2009
lordhelmet's Avatar
*waiting for electric to chime in*
Old Oct 12, 2009
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
in other words you want your cig lighter back. Just pull apart the charger you have take the two wires inside and tap em into your cig lighter from behind the panel As far as fuses go just see what the rating is on the fuse inside the charger and purchase accordingly. that way the wire will not be live with the car off and it'll be the same concept as pluggin it into the cig wire but you wont have to actually lok at the wires or have a big *** charger stickin out and blocking one of your cup holders,(assuming you got a 7th gen) i did the same thing and it worked flawlessly
Old Oct 12, 2009
wikkaco0's Avatar
wikkaco0 is an unknown quantity at this point
The voltage required by USB devices is around 5 volts. If you use your accessory outlet, some devices may not be able to accept the 12 volts. Here's the pin out for a USB. Ignore the two middle pins as they are not used for power.
Old Oct 12, 2009
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
LMAO comedy at its finest
Old Oct 12, 2009
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
The way I did the on my RX8 was to use a 5 volt regulator. It's a transistor that has an input of anything from 5V up to around 20V(depending on the regulator you get). It will output a consistent 5V and can usually source a pretty high amount of current. I would suggest using this sort of setup. something like this http://www.onsemi.com/pub_link/Collateral/NCV4274-D.PDF
GolNat
Suspension DIY
May 12, 2022 06:49 AM
mohawkboom
67
Aug 25, 2015 12:28 AM
hmrflores
Jun 20, 2015 10:41 PM
tylerginevan
Apr 27, 2015 12:29 PM
AzNmiKex215
Nov 29, 2001 08:02 PM
