Electric window problem
Old Sep 11, 2009
rattler's Avatar
rattler is an unknown quantity at this point
2000 Civic EX 2-door 85,000 miles. The driver's window is sluggish going down, no problem going up. The problem seems to be worse in the morning when the weather is cooler and/or damp. What could be causing this?
Old Sep 11, 2009
Re: Electric window problem
try rolling the window down completely, then spray silicone lube in the channels where the window moves thru. put a small piece of paper towel at the bottom so the liquid doesnt seep into the door panel below. let it dry for 10 mins, then try again. you prolly need to do it every month or so when it gets slow again. it fixed my slow and squeaky driver and passenger windows perfectly.
Old Sep 12, 2009
Redd559's Avatar
Redd559 is an unknown quantity at this point
your motors probably dying on you slowly
just take out the door and move some wires around it'll solve it
Old Sep 20, 2009
rattler's Avatar
That worked. i had a can of Liquid Wrench penetrating oil, but i was afraid the 'penetrating' part might damage the rubber, so i used a can of electrical contact spray lube that said it would not harm plastics. works great.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
CarStuff
Dec 6, 2020 12:52 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
timpan
May 18, 2015 07:06 AM
