Need bigtime help here!!
Old Aug 24, 2009
milad333's Avatar
milad333 is an unknown quantity at this point
i have a 97 civic , couple months ago it started having a bouncing idle , but its only between 1900-2000 RPM , it just jumps back and forth, i tried everything nothing worked, so i found a good deal and did a complete swap with a b18b integra engine, got the car back and it still does the same thing between 1900-2000 rpm, and its bad on gas . any tech out there that can help me out please?
Old Aug 24, 2009
D5cIvIc's Avatar
Re: Need bigtime help here!!
did you try cleaning our the IACV? (idle air control valve?)
common symptoms of a flutuating idle is due to that valve on the throttle body. Happens if a motor is left a while without running. All the dust and etc gets in the valve and cause the idle flutuation.
Had that problem when i K swapped. The motor sat for months collecting dust in the throttle body and had a flutuating idle from 1k to 2.5k over and over and over. tried cleaning out the valve with brake cleaner, but still too dirty.
Had to get the IACV sensor replaced and the problems went away.
try cleaning it first then see how that goes.
Old Aug 24, 2009
milad333's Avatar
ya i did that with the last engine and i bought 2 difrent iacv's n same thing, i got new everything in there now engine ,manifold, tranny the whole works n it still does the hunting idle, could it be the fuel system?
Old Aug 24, 2009
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
read this
https://www.civicforums.com/forums/1...e-problem.html
Old Aug 24, 2009
BIG RICH's Avatar
BIG RICH will become famous soon enough
other common problems that causes the "bouncing" idle.....
vacuum leaks
air pocket in cooling system
Old Aug 24, 2009
milad333's Avatar
im gonna try to get the air out of the coolant if there is any, and ill post a reply with the results, thanks
Old Aug 26, 2009
milad333's Avatar
cooling system is bubble free but it still does it bounces 1900 to 2000 quickly and continously
mjpeez
Mar 21, 2009 09:56 PM
Boilermaker1
38
May 23, 2006 11:59 AM
billiardini
Apr 18, 2006 10:05 AM
gearbox
31
Jul 12, 2005 01:20 PM
