Vacume Hose Issue
Old May 27, 2009
dialiciv's Avatar
dialiciv is an unknown quantity at this point
Vacume Hose Issue
Hello I just did a B16A engine swap in my 2000 DX and it has a wierd idle issue.
On the intake manifold there are the two vacume hoses the bigger one and the smaller one. I dont know where to hook the smaller one to. Im guessing it has something to do with the idle. Any help would be awesome.
J~
Old May 27, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: Vacume Hose Issue
Is it just open or did you plug the hole somehow? An open vac leak is a sure cause of idle problems. If its plugged and just maybe not hooked to something, I don't have the slightest clue.
Old May 27, 2009
dialiciv's Avatar
Thanks any way. I found a Vacuum Hose diagram. The opening is pluged but it goes to a peice under the MAP sensor Im gonna try that and then do the timeimg on the car. Should be good I had the same problem like 4 years ago when I helped do a swap in my buddies Civic DX. I'll let you know how it goes.
lildoo
May 9, 2015 09:44 AM
Firefly
80
Sep 23, 2005 11:40 AM
AEMcivic
70
Aug 22, 2004 11:40 AM
huyqvu
Feb 8, 2002 09:22 AM
Black99Vtec
Jan 22, 2002 10:47 PM
