need overheating help!-
I have a 95 civic ex. I bought about 6 months ago and was told it had a slight oil leak only to find out it had a cracked head gasket. it ran like **** so I replaced the head gasket set and a few new O-rings. i also replaced the spark plugs and wires. the car is overheating and idling very bad like its stumbling. it also burns off alot of coolant and oil. iv tried everything i can personally think of so im looking for some help. i need to fix asap plase help. - Mike
Re: need overheating help!-
In the helms manual it says to take a straigth edge, meaning some straight not some off the shelf ruler, and measure diagonally from the top right bolt hole to bottom left,top left to bottom right, and up and down and left to righ both as center as possible. I can't think of the tolerances off hand but if you see a gap with your eye, its prolly warped.
well being that old, i wouldve taken it to a machine shop and have the whole head checked out for warpage, compression, and get it cleaned up. carquest has a machine shop out back if you have those in your area.
well im rebuilding the engine, and if something is wrong with the head i would replace it witha gsr head. this is my first honda so im new to it but my plans are to re do the apexi exhaust and then put a turbo in it. and suggestions on that?
if u want a serious turbo you will need to redo the head with all new parts and I would suggest new pistons. I believe honda pistons are very good and the connecting rods are the flawed part, maybe wrong, but if you just want like 5-8 psi when you rebuild the motor just look over everything and try and get a manual with every internal spec and measure everything. Honda motors last a long time if they are well maintained. But without ever doing a turbo build, I don't know what's good and whats not sorry.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
solarpunk70
Apr 12, 2016 11:43 AM
raymondxcho
Sep 29, 2015 09:00 PM
hondalx2002
18
Sep 15, 2015 10:54 PM
tooly145
Sep 5, 2015 01:05 AM
