Carb swap!!!! Redline or?
Rep Power: 0 Carb swap!!!! Redline or?
Cars runs great 84 wagon 250+ k just out of emissions and I want to clean out all the 2+ miles of vacume line and crap. Need a good direction to go. I wouls rather not replace the intake manifold , but it is and option. I have had this car in my family since father bought it new. New to the thread did not want to ***** around so hope nobody shoot me for posting in 2 spots.....
Rep Power: 275 Re: Carb swap!!!! Redline or?
That is a very interesting project. Just buy a rebuild kit for the carbs. it should come with most everything you need. otherwise you can just cut any additional lines to length and replace them that way.
1 Post
Rep Power: 251 Re: Carb swap!!!! Redline or?
If the car is running great I would not mess with the carbs. if you want to take care of all of those vaccum lines what i would do Is find out the ones you really need Like if you have a brake booster you deffinately need that one or if you have a vaccum advance on a distributor you need that one to. But a lot of vaccum lines are there for just emmisions purposes so you can pull out the line and plug the hole's going into the carbs/intake manifold. but make sure that they are plugged cause if you get Any air in the system it will idle erratically.
Rep Power: 0 Re: Carb swap!!!! Redline or?
I was thinking about just running what I needed ie vacume advance etc. There are 3 other pumps vacume acuated on the carb alone. I have a spare stock carb as well. Its just ya know Yeah I got a Redline on it sounds good for the shop talk. But seriously if you guys think I can get away with just the lines I need I can plug all 33 other lines that are on it...... Yes 33 vacume lines in all. Kinda crazy!
juicetayne
09-30-2015 11:02 AM
ThatGuy913
09-28-2015 05:35 PM
NaturalSelectio
09-06-2015 06:59 PM
