RSX seat airbag question
Old Feb 12, 2009
Apollyon02ex's Avatar
Apollyon02ex is an unknown quantity at this point
Two questions.
If i swap to rsx seats with airbags (and i have side airbags) can you successfully hook up the airbags and make them work?
second question. IF i swap for rsx seats that have already blown their airbags, can i use my civic airbags and remove them and put them into the rsx side airbag housing?
Old Feb 12, 2009
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
Re: RSX seat airbag question
if your civic is equipped with side airbags i dont see why they wouldnt work. and if they fit i would assume they would work...but dont quote me on that caus there are dual and single stage airbags which cant be mixed
Old Feb 12, 2009
Update: Looks like it will indeed fit just fine. Below is the different part numbers. clearly the airbags part numbers are different. But I'd assume that just contributes to different colors. Notice the airbag holder uses the same part number. So in theory, you could interchange acura and civic airbags if they share the same holder.
difference in part numbers: honda 06788-S5A-A80ZA acura 06788-S6M-A80ZA
rsx vs civic use the same airbag holder: part number 81528-S5A-J01
Old Feb 12, 2009
kcari's Avatar
mine fit with no side airbag light or SRS light.
I was getting a side airbag light every so often with my stock seats but now its gone.
we'll see if it'll actually deploy, but who cares - as long as there arent lights im happy
Old Feb 12, 2009
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
yeah it will work the air bag connectors are the same the only thing were you run into the single and dual stage airbags is with the steering wheels. side airbags only come with one stage on the honda's so far
Single stage goes off if you hit anything.
Dual stage does a small charge on low speed collisions and sets off both charges on high speed impact.
Old Feb 13, 2009
thanks for your help guys, I'll let you know for sure tomorrow, as I'm attempting to do the swap tomorrow, rsx seats in em2, em2 airbags in rsx seat.
Old Feb 13, 2009
manahoonie's Avatar
sooooooooo if you get t-boned, and your airbags don't deploy, are you going to check your dash, see no SRS light and be happy?
well, whatever makes you happy then!
Old Feb 13, 2009
kcari's Avatar
lol - a t bone civic is a death cage anyways
Old Feb 15, 2009
just to clarify everyone. the civic seats-airbags fit perfectly in in the rsx seats-airbag assembly.
Old Feb 26, 2009
civex03's Avatar
civex03 is an unknown quantity at this point
Did the RSX seats install w/ no issue? Any modifications have to be done or just put in and screw down?
Old Feb 26, 2009
speedfoos's Avatar
Drop in, bolt down, drive in RSX goodness.
Old Feb 26, 2009
kcari's Avatar
wasnt that easy for me. i had to trim the carpet, took 2 small asian guys to sit on the seat in order to fit a 4th hole only after making the hole of the bracket larger. plus i added a thicker washer to the 4th hole to stop it from rocking. maybe ull have better luck
Old Feb 26, 2009
speedfoos's Avatar
Oh. Well I can't say I call that difficult. If I had to fabricate brackets or drill new holes and weld nuts to the back, I guess it would be difficult, but I'm a little different in that respect.
Old Feb 26, 2009
DRIVER SEAT
approximate dimensions- length, width, height, 1.75, 1.75, .75
the 4th hole does not perfectly line up, it lines up left and right but not up a and down. you need to lengthen the hole towards the back of the seat.
the pink is a rough estimation of what the previous bracket hole was like. the green represents what you need the hole to be. I just used reciprocating saw whatever its called. to extend the hole. you only need to extend it vertically as the image shows.
after that it works fine, i covered my wood in electrical tape and painted whatever came through with black honda paint. also you will need a longer bolt for the 4th one. I couldn't find a longer bolt in my garage that was the same threading, so i rethread the hole for the bolt i did have, i than painted the bolt black. so i suggest going to your nearest hardware store and finding a longer bolt that is the same threading.
PASSENGER SEAT
there really isnt much problems with the fitment of the passenger seat. however they are slightly different, as long as you do all bolts at the same time it will be fine. for example put all the bolts in and slightly tighten them all, if you tighten the fronts all the way the backs wont fit right, same vice versa. if you do them all together they will be fine. you dont need to lengthen any holes or use wood or anything its a semi-direct fit.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
NoobyKid
Jul 13, 2015 07:53 AM
