Overheating Problem???????
I have a 1996 (facelift) and it has just started overheating it leaks from the block from what i can see could the head be warped that bad and the oil cap is mayonaise wich makes me think head gasket gone. what should i do and what could have caused such a problem ??? help please
Re: Overheating Problem???????
There is water pouring out of the water pump (the maintainance hole) what could be the cause of this ???? help please it is a 1.4 16 valve is this a common fault ???
Last edited by BIG DAN; Jan 23, 2009 at 03:42 PM. Reason: wanted to add engine detail
well its obvious the headgasket blew, prolly from overheating caused by either low coolant, bad water pump, air in the system, defective fan or fan switch, ect sensor, etc. when you have the gasket replaced, maake sure you have the head checked because it might be warped and changing the gasket wont help.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
brian257
Jun 4, 2015 08:17 PM
ttharper
May 11, 2015 07:27 PM
