Overheating Problem
Old Jan 18, 2009
hayward_1213's Avatar
hayward_1213 is an unknown quantity at this point
Overheating Problem
I have a 1993 Honda Civic Dx.. it keeps overheating.. when it overheats the heat in the car shuts off, then out of no where the heat will come back on and the car will instantly cool off to the temperature it should be... what could this be?
Old Jan 18, 2009
RyuNyte's Avatar
RyuNyte has a spectacular aura aboutRyuNyte has a spectacular aura about
Re: Overheating Problem
bad thermostat? there are alot of reasons why it overheats, bad water pump, bad hose, no coolant, etc.
Old Jan 18, 2009
04 Honda Civic's Avatar
First thing first is make sure you have coolant, and that there are no leaks. When you fill up your radiator with coolant try to have the front end of your car up. (park on a hill with the nose end facing up) and fill to the top avoid any bubbles. Does it take a long time for your cars temperature to warm up in the mornings? Oh yea feel your upper radiator hose after your car reaches operating temperature and see if the upper hose is pressurized, if not then chances are you have a bad cap
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
brian257
Jun 4, 2015 08:17 PM
ttharper
May 11, 2015 07:27 PM
