Master cylinder reservoir.
I looked at my fluid and not only was it low, but it's contaminated. It looks like "soot" is stuck to the side of it. This obviously needs to be changed but I don't understand why it doesn't mention this in any maintenance schedule. Strange.
Will I have to remove the master cylinder?
If I want to do a thorough cleaning, what should I clean it with? I imagine water is a bad idea but I'm not sure. I'm talking about the reservoir, not the cylinder itself.
How does this relate to the slave cylinder?
What symptoms does a dirty master cylinder cause?
Should I use Honda dot3 or is it all the same?
Re: Master cylinder reservoir.
no we use dot3. brake fluid flush is every 3 yrs, not dependent on mileage. you flush it out with new brake fluid and then bleed the system. get it done asap
ill check the schedule. actually it doesnt mention anything about clutch fluid. and i dont really know much about manual trans anyway. is clutch fluid just manual trans oil?
no its diff, its like brake fluid but with a diff name (clutch fluid) and it disengages the clutch wjen the pedals pushed in. i would just drain the system and take off the reservoir clean it and refill everything and bleed.
I was planning on doing the same. There is nothing mentioned in the Honda service manual about this procedure. I found this link, I think this is how it has to be done -
https://www.civicforums.com/forums/7...tch-fluid.html
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Bruce2
Sep 27, 2015 08:45 PM
powman02
Sep 15, 2015 07:38 PM
dantheman42
Sep 4, 2015 01:10 PM
