Honda Civic 2001 ( D17 Engine..
guys..
i have a problem
my radiator got leak and the water finished the engine tempreature didnt came up but the engine got off and it give some wiered sounds..
after that in my radiator there is a bubble comming
and its making presure..
i changed the radiator and fixed the new one the old one was leak so no pressure
but the new one when i switch off the car and after 7 or 10 hour i open the radiator cap there is some air inside and it come out like a pepsi can..
please tell me the solution
what is wrong
the head gaskit os damage ?
or it can be fixed without opening the head
i have a problem
what is wrong
Re: Honda Civic 2001 ( D17 Engine..
lol okay so basically, I think you have a problem with your car overheating correct? If so make sure you have enough coolant, also check out your lines, see if anything is leaking etc.
wow your grammar is fantastic lol, first i want to point off a few wrongs, after 7-10 hours of driving why would you open up your radiator cap? What do you mean by your engine got off ? After that there is a single bubble coming from the Radiator? Should definitely fill with coolant, but it sounds like you may have a blown head-gasket.
So.... what's the problem? The coolant bursting out?
If your car has been running for that long, that shouldn't be surprising. The radiator builds pressure to maintain the temperature from being too hot. It burst out like that because the engine is extremely hot and all that heat/pressure escaped from the rad, causing it to burst "like a pepsi can".
If you think that's a problem, I wouldn't worry about it. Unless your problem is something different...
LionSpratt
Jan 29, 2017 11:07 PM
jessicakaybby
Apr 20, 2015 12:11 PM
