Rebuilding an engine. Any suggestions?
Old Oct 15, 2008
Fishoutofwater's Avatar
Fishoutofwater is on a distinguished road
I have a 93 civic dx coupe that's been sitting in my garage for almost 2 years. i originally bought it to fix it up and finish the body work, paint it , and sell it. but that never happened. and with my truck getting 10 mpg i figured why the hell not get this thing on the road. it runs and drives but it has 173k on the clock. and i know its got potential i just don't want to do anything with that many miles on the car. i thought about getting a swap but don't have the money for that. so me and my friend are probably just going to pull the motor and rebuild it. the thing is i know almost nothing about rebuilding a motor. he knows a little bit but i was wondering if anyone had any tips or suggestions to help me out. any help is much appreciated, thanks
Old Oct 15, 2008
HLC's Avatar
HLC
HLC is an unknown quantity at this point
Re: Rebuilding an engine. Any suggestions?
buy the service manual...that in and of itself is more help then i could possibly give you
Old Oct 15, 2008
EM2MAGMET914's Avatar
EM2MAGMET914 can only hope to improve
ok well first u could go searchin for diagrams or w/e so u kno basic layout of wuts comin out, make sure u have all the right tools dont wanna start pullin the motor to find out u gtg out to buy like a piston ring compressor, LABEL or TAKE PIX of EVERYTHING all the lil screws and bolts and stuff so u dont end up putting ur motor back together and u see u got a pile of hardware left over and u dont kno where the hell it goes, take it apart..clean everything thoroughly, inspect all parts for wear, chips, cracks, etc buy any new things u might need, now would b a good chance to upgrade anything u have in there if ud like, and have fun? lol its gonna b a great learning experience i remmeber whn i took apart my first motor in school i was kinda lost cuz it was an american motor lol! but after the first time doing it slow n takin notes remembering how stuff went and the basic idea i could strip down and clean n put it all back together in like under an hour well done so take your time and good luck!
Old Oct 15, 2008
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
Breaker Bar, Hammer, Tools, WD40,Service Manual And Boxes and bags And some cool music....
Old Oct 15, 2008
yeah i plan on getting a manual and some diagrams so i know how everything comes off and goes back on. im also gonna try to upgrade all the small things that i can that'll be easier wehile the motor is out. and ive learned from experience to label **** and not lose little screw and bolts. been there before.
Old Oct 15, 2008
dont upgrade to much just go OEM unless u find crack head prices on some other stuff. Internals OEM all the way bolt ons like manifolds and little things get aftermarket, if it breaks its easy to fix not like something internal
Old Oct 15, 2008
yea deff like dont go over board thinkin oh now its apart i should get better pisons and a new crank performance cams etc...thats farther down the line if u plan on goin crazy with it....I/H/E is usually best to start off with n give a motor as long as u get the breathing done u get alot more space and availability for bigger things
coughturbocough hehe
Old Oct 16, 2008
oh yeah as soon as shes up and running i plan on getting a turbo
Old Oct 16, 2008
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
building a motor is all about clearances. if the bores need boring or even excessive honing, ull have to get new pistons and rings. if there isnt a ridge on the top of the deck outside the cylinders, you may get away with a slight hone and keep the original pistons. youll want to get new rings. have the head and block checked and milled to make sure the deck is flat. thats usually pretty cheap. i pressure check and mill heads for around $60 and its well worth it. you can also have new seats, guides, seals, and have the valves done for extra insurance. you dont want to put it together and it smoke or have low compression on 1 cylinder. if you dont know a lot you can get a machine shop to check and assemble the bottom end to make sure all bearing clearances are in spec. too lose or too tight and ull be pullin it back out. if you plan to abuse the motor doing it right the first time will be worth the effort and money. make friends with a good machine shop that is fluent in honda engines and ull be fine. they have the tools and experience to make sure its done right.
Old Oct 18, 2008
any specific type of manual i should get? i want like a diagram and **** i want to see exactly how it goes back together cause the last thing i need is to miss a piece. im in no rush cause the cars probably not going on the road till spring but i wanna get this done soon.
Old Oct 18, 2008
ksuggs8503's Avatar
ksuggs8503 is an unknown quantity at this point
man just make sure you label everything good and hone the cylinders, change the rings and gaskets, timing belt, water pump, etc I just did my 93 a week ago and it started first try. using haynes manual
Old Oct 18, 2008
i would get a factory service manual. you can pick one up at honda for less than $100. well worth the money
Old Oct 19, 2008
i got the haynes manual but havent really used it. probably gonna need it alot more when putting everything back together. but we got most of it done. we got the headers, head, intake manifold and everything off. just have to figure out how to get the block out without a lift
Old Oct 20, 2008
Drop the motor onto crates or something. Its a little motor u can probly lift it aslong as most of the stuff is off and drained i lifted my d17 with 2 friends. no tranny no oil
Old Oct 20, 2008
i was goingw to do that but i bought a motorcycle lift to lift the engine and were going to lift it and take off all the motor mounts, then drop the motor, life the car a little bit, and pull the motor out. a little unconventional but lets hope it works
JohnnyBxo
Nov 12, 2015 03:04 PM
Dani1993
Jul 24, 2015 09:02 AM
estes53
Jul 20, 2015 10:43 PM
manfredww1
Jul 14, 2015 10:24 AM
Hqly2001
22
Jul 12, 2015 06:44 PM
