headlight adjustment for 04 civic need help
Hey guy, Im having trouble find the area where i can adjust the vertical up and down of my headlights in my 04 civic coupe i saw the 01-03 DIY but seems different . can u guys show me a picture of where it is
i see the U with the (u) and (d)
but dont know where the screw is
thanx
thanx
Re: headlight adjustment for 04 civic need help
you can use a philips screwdriver too by sticking it to the side of the gears. park 25 ft from a white wall at night, on a flat surface. measure from the ground to the center of the headlight, then go to the wall and measure the same distance and make a mark. the lower headlight cutoff should be 2 inches below the line you made.
usajags84
15
Aug 19, 2015 03:12 AM
