Cracked Manifold, Need Help
Old Aug 27, 2008
seelsy's Avatar
seelsy is an unknown quantity at this point
i took my carf in for an oil change and was told i have a crack in my exhaust manifold. he said its not a pressing problem but will become one later down the road and they want nearly 1000 bucks to replace it. i know 90 percent of this is hondas screw the customer price mark up so does anyone know where i can buy an exhaust manifold for an 02 civic lx coupe, or if i have any other options, such as buying stainless headers or something??
Old Aug 27, 2008
lordhelmet's Avatar
Re: Cracked Manifold, Need Help
Use the forums. I picked one up for 60 bucks shipped. Just threw it on 2 weekends ago and the car runs great.
Old Aug 27, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
$1000 bucks sounds about right because the cat is built into that header I believe you can get a stock replacement for around $300 or you can try to upgrade it which if you search will be even cheaper
Old Aug 27, 2008
wikkaco0's Avatar
wikkaco0 is an unknown quantity at this point
Theres an 8 year warranty on the exhaust manifold / catalytic converter on the LX civic. You might be in luck if you bring that up.
Old Aug 28, 2008
lordhelmet's Avatar
its 8 year or something like 80000 miles.
Old Aug 28, 2008
TRIZ's Avatar
Check out my exhaust FAQ in my sig, it lays it all out if your looking to swap it over. Buying used is the cheapest alternative, just get a low mileage part. Or if you swap to an EX exhaust, you can pick up the random technologies downpipe with high flow car for pretty cheap.
Old Aug 31, 2008
seelsy's Avatar
anyone know a company that makes an aftermarket header with a catalytic converter inside? or do i need to buy that seperatly and have a shop weld it inline
Old Aug 31, 2008
TRIZ's Avatar
There really isnt much market for an aftermarket header with a cat in it... most of them just yank the cat out. There was a comany coming out with a dx/lx header in the past month for our cars, the name just slipped my mind. I'm not sure if it had a cat, I am thinking it did.
Old Sep 1, 2008
lordhelmet's Avatar
I think it might have been magnaflow but I'm not sure.
Old Sep 1, 2008
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
or you can always buy the one i have sitting in my garage. but honestly unless its a big crack it probably wont be a serious problem for a long time.
Old Sep 2, 2008
lordhelmet's Avatar
He should probably replace it. I didn't think my crack was to bad because I wasn't throwing a CEL. I pulled it off and there was a crack all the way around the 4th pipe.
styles234
21
Nov 19, 2019 07:23 AM
SammySC
121
Apr 7, 2017 07:43 PM
raymondxcho
Sep 29, 2015 09:00 PM
rovafa2002
Sep 28, 2015 06:57 PM
Mannimarco
Sep 7, 2015 10:01 PM
