Awww man, intake manifold leaking.
Old Jul 6, 2008
  #31
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: Awww man, intake manifold leaking.
Honda will always tell you to buy Honda genuine parts...wonder why?
cuz its Honda!
they go on about warranty, and then so they can make the money on parts cuz that where the make the most money from...parts!
Ex: there was only a 1200.00 mark up on my 06' Civic, not much really.
dont worry about them, buy what you want as long as you research the stuff first.
Old Jul 6, 2008
  #32
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
cuz its Honda!
Haha, honda tech is a forum like this one. Not honda tech support. ^_^
I just don't know what brand to go for if I go aftermarket. Cometic, fel-pro, et cetera. It's weird, fel-pro makes an MLS HG for the civc, but it says not for racing for all their products. Since when wasn't MLS not for racing?
Old Jul 6, 2008
  #33
greeen01civic4d's Avatar
if ur going aftermarket headgasket, use cometic, but its not necessary, just get a honda oem one and use ARP headstuds.
Old Jul 6, 2008
  #34
I thought ARP head studs are only necessary with steel HG. What's the point with a stock HG? Is torque the same with ARP studs?
Old Jul 6, 2008
  #35
torque is higher with arp, and my headgasket was steel, and i got it from honda.... then again i have an 01. arp headstuds arent that much more expensive than oem, and u can reuse them. actually i got mine(arp) for less than oem by about 10 bucks, because summit has a coupon right now for 30 dollars off a 100 dollar purchase or more, and they were 105 with shipping, so i got em for 75 bucks
Old Jul 6, 2008
  #36
FGCOUPE's Avatar
steel hg & ARP studs are used in boosted applications (T/C or S/C) whenever the pressures get to much for OEM, otherwise your head will come right off the block. But if you dont want the hassles of a possible OEM problem then this would also be ideal.
.02
Old Jul 6, 2008
  #37
What's the coupon? I want to order...
Old Jul 6, 2008
  #38
.02
That's my logic. I would rather go with cometic steel. What is a DX any way, .30 and 76mm?
Old Jul 6, 2008
  #39
I'm discussing this here: http://www.honda-tech.com/zerothread/2337547
One guy said:
Lol!!!
Just go stock HG and Studs. You dont need any aftermarket on stock engine unless you are a ricer and whant to brag to your friends that you gained 50hp because you have a Cometic HG. Get a y8 from a 96-00 EX enginehead gasket which are about $35 much cheaper then any other engine at Honda from what I understand. I always re-surface my heads just to be safe so maybe its not a bad idea if you do it.
Old Jul 6, 2008
  #40
well at least he mentioned checking the head for warpage lol.
Old Jul 6, 2008
  #41
dude, this sucks, i had this set aside, and my wife through the coupon away, if i find it ill pm it to you
Old Jul 6, 2008
  #42
FGCOUPE's Avatar
although im not quite sure what year civic you have nor what motor...
here are a few, but im sure if you continue to search like i did on google youll find something??
http://www.tunerschoice.com/xq/aspx/...qx/product.htm
Old Jul 6, 2008
  #43
I can find them, I just don't know the hole diameter. It's either 75.5 or 76. It's a 1997 D16Y7.
Old Jul 6, 2008
  #44
FGCOUPE's Avatar
oh....ic!
hmmm?
cant Honda tell you, or maybe a Haynes manual or some crap?
Old Jul 7, 2008
  #45
oh....ic!
hmmm?
Good idea.
Old Jul 12, 2008
  #46
Test.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
