Oil in Air Filter Area
Old May 12, 2008
jjackson224's Avatar
jjackson224 is an unknown quantity at this point
2002 honda civic lx.........My car dies when in idle but once it gets going it runs fine. I took off Air filter and noticed oil going down the motor from the top. What could possible be the problem? It also is burning/wasting tons of oil. Any help?? Please???
I have changed spark plugs and put new air filter. No luck.
Old May 12, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: Oil in Air Filter Area
its natural. if your refering to the hose that connects from the top of the valve cover to the intake box then thats normal. any other place than that, oil anywhere else is not normal. its just a random thing with engines. some engines have blowby and some engines dont. blow by is what causes the oil to reach the top of the valve cover and into the intake, where it burns off.
your idling problem is a different issue. how many miles are on the car? maybe its time for a valve adjustment.
Old May 12, 2008
jb1004's Avatar
jb1004 will become famous soon enoughjb1004 will become famous soon enough
I'm no expert but it sounds like it could be a head gasket. How does your coolant look?
Old May 12, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
yeah^
head gasket?
how many miles on the car?
any codes?
Old May 12, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
If it idles like *** and runs fine, the Idle air control valve is clogged. Take off the throttle, spray throttle body cleaner in the throttle... the rectangular slot in the side of the bore is the valve passageway. Clean it out.
You can thank the EPA for the gunk.
The burning oil needs more diagnostics. Do a compression and leakdown test and see if the motor is still all sealed up. If its oil (blue smoke) it wouldnt be the head gasket. If its burning white, then look into the headgasket, as white smoke is coolant.
Old May 12, 2008
It has 80,000 miles. It is fine on coolant. Not losing any coolant. Where do I get codes from???
Old May 13, 2008
jb1004's Avatar
In order to get the codes you need a scanner. If you take it to auto zone or somewhere like that they can generally check them for you. If you don't have a check engine light on though, you shouldn't have any codes to read.
Ninetyatecivic
May 9, 2015 07:48 PM
carid
Apr 30, 2015 07:00 AM
joe
Dec 10, 2001 10:33 AM
