Just got HID fogs. Is this how I switch a relay?
Diamond Member
Red = Positive
Black = Negative
Does ground = negative?
So on the ballast, do ground the black wire coming FROM the ballast, or do I get it to the negative battery terminal? And same for the switch.
Black = Negative
Re: Just got HID fogs. Is this how I switch a relay?
ground = negative battery terminal or chassis connection (which is connected to battery). you ground the ballast (-) wire to the chassis or (-) terminal. power gets connected to the harness. i dont really understand your drawing tho
Diamond Member
the thing in the middle with the numbers is the relay. the switch is on the upper right. the battery is on the upper left. ballast middle left.
oh okay lol i didnt know that was a switch. it seems right to me idk. check this thread to be sure and maybe suvlights.com too
http://www.rowand.net/Shop/Tech/Wiri...ightRelays.htm
mjdiaz89
Jun 21, 2016 09:26 PM
cizsak
Jul 21, 2015 03:39 PM
Kyles24
Jul 12, 2015 09:15 PM
