I Need Some Help!!!
Old Dec 1, 2007
nociv1's Avatar
nociv1 is an unknown quantity at this point
Exclamation I Need Some Help!!!
Ok heres the problem. My freind has a 95 civic ex with a 97 motor in it. On the ignition system they have an external MSD coil. Well the wires going from the coil to the distributor were kinda pinched in the distributor cap so the wires isulation wore off and were grounding themselfs out so the car had no spark. Well heres where it gets interesting. I replaced the wires for the MSD and ground a hole in the distributor cap so they wouldnt rub anymore. I have spark now which is what we thought was the problem because it wasnt sparking. I have fuel i have compression and the timing is right on. However the car still wont fire over and im just out of ideas. Is there any sensor that could keep if from starting even though we have fuel air spark compression and timing which is basically all you need to get a motor running. The motor wont even POP like it wants to fire so im confused any help would be greatly appreciated.
