Ls Vtec build!!!
ok i blew up the old b16a2 but bought a b18b block. i now have....
Eagle h-beam rods/Eagle crank
JE 10.3 compression pistons
Eagle block gaurd
Comp cams,valve springs,retainers
Manley valves
Aem fuel rail
DSM blue top injectors
skunk2 cam gears...
so now all that is left is the vtec conversion and i was wondering what would be a good one for my build? also, if anyone has any advise as to what other things i can do to my engine just shoot im open for suggestions. But remember im already boosted and i now have a 75 shot 1 stage kit. and i will post pics of everything very soon!!!!
thanks for reading!!!
-civic pride-
Eagle block gaurd
Manley valves
Aem fuel rail
skunk2 cam gears...
-civic pride-
Re: Ls Vtec build!!!
Golden Eagle has a good rep for the vtec conversion kit.
http://www.goldeneaglemfg.com/street.html
How much are you planning on boosting and what are you using for engine management?
blue tops are usually 450cc. those might not be big enough dependant on how much boost you want to run. you should be able to push 450-500whp dependant on your set up as well(turbo and all- i/c, what manifolds your running inc. t/b, engine management, wet or dry nitro system and where its being injected, ect)
well first i have a hondata s300 system to tune with (which i have heard great things of so far!!) my system is a dry shot kit, i am taking my next 2 checks to buy a victor x intake manifold from edelbrock, and i should be boosting somewhere from 22-26 pounds it just all depends on how it is tuned.
thanks for the responses
are you going to sleeve it? It would be a good idea if you sleeve just for piece of mind and so you can upgrade for more power down the road.
If you sleeve it, i suggest you use the 84mm pistons and go with the larger displacement.
sounds like the motor is alreay built to me, where are you spraying the nitrous? in the manifold, before the turbo at the intercooler?? this is going to help determine the amount of fuel needed as well as boost. dry shots rely on your present fuel system to account for the nitrous. i would suggest using this type of nitrous system on the intercooler inlet. this way the major benefit for the nitrous is colder intake temps.
yea i really thought about running the spray to the intercooler but i still think its going to be going thrugh the intake mani. so wat injectors would everyone suggest though. and if i ran it through to the intercooler where and how much would it cost to change it???????????? thanks everyone
your probably going to need between 650-750cc injectors. With a good tune w/o the spray you should be able to put down 450-500whp. I would seriously consider using the spray on the i/c rather than the intake mani. a dry shot leaves lean spots in your rpm band. this is due to the fact that the system has to trigger the computer to inject more fuel and there is always a delay, this delay gives nitrous with out fuel for a very short period of time.
this is not something you want with a boosted application. that .5 sec could cause detonation and ruin the work you just did.
yea i actually did some research about the spray and have decided to move it to the intercooler. i thank you very much for the suggestion b/c i got the saame response from the nos techs i talked to. and have ordered everything for the i/c. so thank you very very much for that. next does venom make an injector for my car that big. and if not then is there a certain brand i should be looking into???? and how much is an aem fuel regulator?and fuel rail? and i just bought an aem wideband controller is this goin to be good enough for this build??????
that UEGO is a good wideband. that will be ideal for your set up. also you may want to consider like a full race manifold. it will be a little more expensive but will produce more power. either that or a PWR manifold. I like the carbon ones
aem is also good for the rail and regulator if not look into aeromotive. dont go cheap on this because inconsistant fuel pressures will be the end of your motor. Re: Ls Vtec build!!!
if you dont mind as well can i suggest a good book. i promise it will keep you interested and you will learn TONS
Maximum Boost
by Corky Bell
By far the best educational book for building a turbo set up.
Maximum Boost
by Corky Bell
neighbor wasnt home last night so i didnt have a chance to speak with him about the injectors.
Do you read Dspport magazine?? I have a series of issues that does a build up on a b16 sleeved and boosted although with 84.5mm bore. This gives a little better R/S ratio and allows you to rev a little bit higher. Like 10k LOl. but they made about 675whp on a similar set up. I think you would love to read about it. I hate to part with them but let me see what I can do.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Touge
Sep 22, 2015 11:55 PM
Touge
Ottawa
Sep 22, 2015 11:52 PM
Touge
Touge
Sep 18, 2015 12:13 AM
