Door panel removal?
Old Mar 30, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
Door panel removal?
I know toastyghosty? or someone posted a diy on how to remove the door panel awhile ago but now its gone. [IMG]i/expressions/face-icon-small-sad.gif[/IMG] Can someone please tell me how to remove the door panel do i can install my m3 mirrors? Also if anyone know where this thread is a link to it would great too. Someone please help it would be greatly appreciated.
Old Mar 30, 2002
sevenincubus's Avatar
sevenincubus is an unknown quantity at this point
maybe the one under DIY at the top might help. it talks about reomving door panels to change out speakers.
Old Mar 30, 2002
Wow thanks didnt even see it!
Old Mar 30, 2002
PeArlHoNdA's Avatar
PeArlHoNdA is an unknown quantity at this point
lol i just searched this very same thing earlier today and found nothing....then u posted lol. i missed that DIY as well.....im just a "member" though so i guess im still nO0B!
*goes to DIY*
PeArLhOnDa
Old May 1, 2002
Chlorine's Avatar
From: Toronto, home of the Leafs!!!, Ontario, Canada
Chlorine is an unknown quantity at this point
ok, I see the DIY but I'm not really understand it... maybe I'm just dumb... but could someone help me out?
so remove the two screws inside door handle compartment thingee... I can do that. after that, I have no clue... btw, I'm trying to remove all door panels including the rear ones (I have a sedan). I have power windows/locks... so what exactly do I do after removing those two screws...
<< Detach door latch by prying out from front,
and detach door latch connecting rod from clip by first unclipping it,
then popping the rod out from underneath.
I don't even really understand this part
<< Remove power window switch panel (front of entire door handle).
Contrary to earlier reports, it is not necessary to remove the rubberized rear section of that.
Pop out the front of the handle, and slide forward. Remove the two screws you see in picture 3.
it says remove, do I just grab it and push it forward?
obviously I have no idea what to do... I'm just afraid I can't open the door after I do this... like removing the rod and all... that's why I'm starting at the back
anyway, for those of you who have done this, please help.
Old May 2, 2002
Chlorine's Avatar
still waiting for help... come on, I know many of you have done it....
Old May 3, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Just do it...it's not that hard. Remove screw from door handle and from door latch. Then pop the door handle off (just pull up). If you have power windows you'll have connectors that need to be detached. Then their are two screws holding the panel to the door. After unscrewing those, there's a spot by the speaker where you can pull up. The rest is held on by snaps. Just pull...after all of them are popped push up the the outside corner of the door panel...then slide the door off. Put the door back on the same way...it's a PITFA, but you can do it.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
h4ldol
Jun 3, 2015 03:26 PM
MamaBear2015
May 18, 2015 07:37 PM
timpan
May 18, 2015 07:06 AM
MamaBear2015
May 3, 2015 02:17 PM
