I NEED HELP!! Something went wrong
Old Mar 28, 2002
HP's Avatar
HP
HP is an unknown quantity at this point
Hi! I really need some help now!! I tried to install my springs today and started with the front. Everything went all right on the left side BUT on the right side the strut assembly just wouldn’t be put into place… [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
I had a friend over to help me and we fought it for a long while and then discovered that the driveshaft just won’t go back inwards allowing the knuckle to fit to the strut. So in other words the “wheel” stops at about a one o clock position and you feel that it is the driveshaft that's stopping it. Even with the strut assembly completely removed it won’t sit straight. [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
So if anybody have an idea on what to do or what’s really gone wrong please help!
Old Mar 28, 2002
SpeedRacer's Avatar
SpeedRacer is an unknown quantity at this point
clamp the springs more. it will fit. check the top part where the 3 bolts are (where you would put the strut bar) make sure they're lineing up the right way.
Old Mar 28, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Make sure the car is out of gear (neutral) so that you'll have more play in the wheel, that might help.
Old Mar 28, 2002
HP's Avatar
HP
Yeah, but it wont sit straight even without the spring/strut.
Edit: I tried it in neutral. You can feel the shaft going in more when you spin the shaft to certain positions but it just won’t go in long enough. It is almost like it slipped out of its place somehow.
Old Mar 28, 2002
AEMcivic's Avatar
Damn, that doesn't sound too good[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
But I don't think it slipped out of place.
Is your steering locked, maybe if you put the key in and turn it to ACC it will turn some more...
BTW, if I remember right, you do have to "pivot" the whole assembly up into position. But I'm sure you figured that out if you finished the other side already. If you got one side, you sould be able to get the other side, it's the same exact thing. Just double check everything and make sure that a screw didn't fall anywhere it isn't supposed to be and jam something.
Old Mar 28, 2002
VNlilMAN's Avatar
The Standard One
what exactly is the drive shaft? i'm thinking its tht bar that goes from the strut to the engine bay... maybe you installed the left side wrong?
Old Mar 28, 2002
HP's Avatar
HP
Since the tie rod is disconnected the knuckle and everything moves freely so I don’t thinj that would help. Thanks anyway. Keep the ideas coming! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
VNlilMAN: The drive shaft is the driving axle that goes from the transmission/gear box to the wheels. And the tie rod is the rod that connects the steering to the wheel. (or so I think [IMG]i/expressions/face-icon-small-smile.gif[/IMG] It’s kinda difficult with all the english terms when you don’t exactly speak the language every day [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Mar 28, 2002
AEMcivic's Avatar
<< Since the tie rod is disconnected the knuckle and everything moves freely so I don’t thinj that would help. Thanks anyway >>
haha, yeah, that's true. I wasn't thinking
Old Mar 28, 2002
VNlilMAN's Avatar
The Standard One
damn now i'm scared to drop my car.. i was planning on doing it this saturday....
Old Mar 28, 2002
ayzan's Avatar
ayzan is an unknown quantity at this point
Okay, let me get this straight...you pulled the hub assembly towards you which cause the axle to move outward correct? Now the axle will not go back in place correct? If this is the case, then what you did was pulled the cv axle too far out which dislodged from the inner cv joint. You will have to remove the inner cv boot (boot near the transmission) and put the bearings back on the rod and place the bearings and rod back in the inner housing. You will have to repack it with grease and then place the boot back over the inner housing. Make sure you do not get any dirt mixed with the grease.
Old Mar 28, 2002
1973's Avatar
1973 is an unknown quantity at this point
diy is great, i try to do as much as i can myself, or with the help of friends, but WTF, for $100 putting springs onto a car with mac. struts just ain't worth it........
Old Mar 28, 2002
HP's Avatar
HP
Ok, thanks! I guess that's what happened... I will try that tomorrow! Just hope I have some grease left. Stores are close tomorrow I think.
Old Mar 28, 2002
VNlilMAN's Avatar
The Standard One
HP, how hard/far did you pull it? cause i dont think i would know how to put it back in the way ayzan said to
Old Mar 28, 2002
HP's Avatar
HP
I didn’t really pull it, I guess it just fell down to hard or something??? But if you are careful it shouldn’t happen. So do not pull on it [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 29, 2002
HP's Avatar
HP
Problem solved! Once the boot was off you see how to get the joint back together.
Old Mar 29, 2002
ayzan's Avatar
Good job HP. I kinda new it was the inner cv joint. Did you put all the bearings back in place and repack with grease?
Old Mar 29, 2002
HP's Avatar
HP
Thanks [IMG]i/expressions/face-icon-small-smile.gif[/IMG] And thanks for the advice! [IMG]i/expressions/beer_yum.gif[/IMG] Yes I did, now I only have to get new bands that hold the boot. So the car stands jacked up for another day.
Old Mar 29, 2002
ayzan's Avatar
you can use the ones that are for heater hoses. Just make sure it's the right size.
Old Mar 31, 2002
VNlilMAN's Avatar
The Standard One
aiite i tried doing the front but after reading this post i got scared my sh*t was going to come out too... one question, when you take out those 2 lower bolts, is the brakes supposed to just hang?
Old Mar 31, 2002
HP's Avatar
HP
After I got everything back together I used a piece of wire and tied it up so it wouldn't fall out again. However it really doesn't go anywhere until you remove the strut. It helps if you have another person to help and support it while you remove the strut.
Old Apr 1, 2002
2Hondaz's Avatar
2Hondaz is an unknown quantity at this point
Before you let the rotor/hub assembly fall over once it's unbolted, place your floor jack under the bottom of the rotor and jack it up just enough to touch the rotor. Then slowly let the jack down enough to remove the strut. You don't have to let it go too far. If you do it this way, you won't have any problems.
Old Apr 2, 2002
VNlilMAN's Avatar
The Standard One
damn, now someone tells me...
ricer_em2
May 11, 2016 08:09 PM
speedlever
Sep 24, 2015 07:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
