Adding a sixth gear?
Old Jun 29, 2007
Toaster's Avatar
Toaster is on a distinguished road
I am probably going to have to have my transmission rebuilt. I remeber reading an article in Honda Tuning a while back that SI and RSX people can add the sixth gear from the TYPE S (Of course there is more to it than just the gear). Was wondering if there was anyway to do it with the transmission on the D17 series. I would guess if there was a D17 series with a sixth speed it would be possible. I would not think you could use the gears from the TYPE S and put them on the shaft of the D17s and am guessing you could not just swap out internals all together. Just a thought/question. Call me dumb if you wish.
Old Jun 29, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Adding a sixth gear?
No you cant. There's no room in the case.
Old Jun 29, 2007
MidnightCivic's Avatar
ill call u stupid instead
Old Jun 29, 2007
DsevenEm2's Avatar
This is Myspace
oh wow harsh...its not stupid though...thats actually a cool idea..ADDING ON A GEAR whats stupid is adding on a gear to the d17 tranny or any civic tranny for that matter. the cost/custom work/time/patience to benefit ratio once again... is at a huge disadvantage.
Old Jun 29, 2007
Syke Fu's Avatar
Syke Fu will become famous soon enough
Rick James says:
You are cold as ice!
Old Jun 29, 2007
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
That would be phat if you could just like pour a bottle of "Nu-Gear" in your gas tank and it would build a new gear in your transmission.
This would only work if there was such thing as a six speed EX, which there isn't so no..... I maybe you could mate it to a GSR six speed or something like that who knows what'll fit....
Old Jun 29, 2007
speedfoos's Avatar
Ooo ooo!! Eyger!! PM me with a shipped price o f your Nu-Gear! I'm on it like vomit!
Naw, good idea, but unfortunately wishful thinking. Redline at 129 mph in 5th gear is kind of crappy.
Old Jun 29, 2007
Toaster's Avatar
Thanks for all the replies. I figured since there was no 6 speed EX it would not be possible. I had not thought about the case issue. I do not know much about building/rebuilding transmission but asking questions is how you learn.
Old Jun 29, 2007
tougEMII's Avatar
tougEMII has a spectacular aura abouttougEMII has a spectacular aura about
i think if ur going to add a 6th gear, ur gonna have to change up all the ratios of the previous gears to work out right. waste of time imo. but cool thought of having a 6spd single cam?
Old Jun 29, 2007
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
the one thing u'll have to remeber is that a new linkage would be needed... i have no idea if there's a swap... but i woould think you could fabricate one from the k20 tranny thats a six speed because it seems to have the same linkage...
so.. i would think you would need...
a k20 type s tranny linkage
find out the gearing on a the d17 tranny
rework gearing
new bearings
custom input and output shaft
i would recommend a new clutch
maybe a different differential
now.. i no this is all jus hypothetical... but if u needed any info on tearing out the tranny.. i have done it twice andopened the tranny.. i am also currently workin on a diy
Old Jun 29, 2007
sl33pyriceboi's Avatar
LMAO @ this thread......the stupidy of ideas....
just swap a k20 in ur car. then you'll be an EX with 6 speeds...lol
Old Jun 30, 2007
speedfoos's Avatar
Not stupid at all. Obviously none of us who have posted so far have tried it, or even gone down the road of seriously seeing if its even possible. I would love a 6-spd D17, but don't have the technical know-how to try things out to see if they would work with some fabrication or not.
Old Jun 30, 2007
ex2k3's Avatar
diamonds she will pretty much have to
ex2k3 is a jewel in the roughex2k3 is a jewel in the roughex2k3 is a jewel in the rough
it's not stupid in theory, if you're trying for better fuel economy (4k rpm @ 80mph sucks) or reaching for high numbers (250-275+hp). it would be stupid on cost-to-benefit though since you could get a k20 with 6 speed and more hp for less money.
Old Jun 30, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Its stupid cause you CANT DO IT ON A D17! and there is no use for it.
Old Jun 30, 2007
Alpha 5's Avatar
WOW!!
You can't put a 6 speed on a D17.
You can't get 200 HP out of a NA D17.
You can't put a super charger on a D17.
You can't out run a meter maid with a D17.
Intake does nothing for the D17.
A Header does nothing for the D17.
You can't put an exhaust on a D17 with out a turbo and make it sound good.
What is with all the negetivity?
The reason Honda put the D17 in the ULEV Civic is because it is a ULE motor that gets 30+ MPG.
If you want all the things stated above do a swap or get a diff car.
Old Jun 30, 2007
Civicman1988's Avatar
How much you want to bet you can?
Old Jun 30, 2007
Alpha 5's Avatar
Here we go again!
Here is where the 200 HP on a NA D17 conversation is, if you would like to chime in.
https://www.civicforums.com/forums/1...hp-all-na.html
Old Jun 30, 2007
lewolved's Avatar
lewolved is an unknown quantity at this point
[QUOTE=Alpha 5;4209516]WOW!!
QUOTE]
with a little work done with d16y8 JRSC you can make d17 SC....
Old Jun 30, 2007
you can do almost anything....it will cost a pretty penny but its possible.
Old Jul 1, 2007
Anything is possible, if you truly believe and have enough money!
nirvanaguy
25
Oct 26, 2017 07:26 PM
Donahue
Sep 8, 2015 09:00 AM
NaturalSelectio
Sep 6, 2015 06:59 PM
tommycanada
Sep 5, 2015 04:59 PM
gmiguel
Jul 30, 2015 10:52 AM
