Cali Smog folks...
Old Jun 14, 2007
feedphillipnow's Avatar
feedphillipnow is an unknown quantity at this point
Cali Smog folks...
This Civic I bought recently wasnt smogged, I smogged it and it failed. The guy at the shop was going to do a diagnostic to see whats up. For those who are familiar:
NO (PPM)
California max...720 Measured....2374
HC (PPM)
Max ..93 Measured...118
CO %
Max.... 0.57 Measured.... 0.69
I was thinking it just needs a cat converter and fan relay (fan not clicking on)
The NO/PPM is pretty damn high though isnt it... Its a "gross polluter"
Just wondering what some thoughts may be...
Thanks... I cant register it, sort of sucks.
Old Jun 14, 2007
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
Re: Cali Smog folks...
get urself a random tech high flow cat...it comes with a carb exempt card and it WILL pass smog.....
Old Jun 14, 2007
djmota's Avatar
NO (PPM)
HC (PPM)
CO %
those measurements make me think the cat has been really damaged or hollowed out/missing pick up a random tech and you'll be stylin.
Old Jun 14, 2007
Yeah its the stock cat. SO its probably been through alot... the numbers would drop that much after replacing a new cat? I got all freaked out.. what local places carry thesE? I didnt see them at kragen... just walker and magnaflow..
Old Jun 23, 2007
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
a good way to see if your cat is working or not, (aside the engine light) is take the car for a drive. get the cat warmed up to normal. then using a infared tempeture meter with the engine still running mesure the input pipe to the cat and the output. output should be HIGHER than input. if there EQUAL then the cats no good and or not doing it's job.
JetsterDajet
52
May 8, 2016 12:11 AM
solarpunk70
Apr 12, 2016 11:43 AM
deanaZoom
35
Sep 19, 2015 12:22 PM
CivicsClass101
Jul 9, 2015 11:14 AM
