Looking for 05 Stereo Install
Old May 9, 2007
wragen22's Avatar
wragen22 is an unknown quantity at this point
I have a 05 coupe that i want to install my aftermarket stereo in. Can anyone help me out here? I have a wiring harness and kit from my 00' accord. Will these work?
Old May 9, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Re: Looking for 05 Stereo Install
Harness should work, kit won't.
Old May 9, 2007
mike21190's Avatar
mike21190 is an unknown quantity at this point
I just put in an aftermarket stereo in my 03 sedan. Ill walk you through it if you need help
Old May 9, 2007
wragen22's Avatar
A walkthrough would be great. Where is the best place to get a kit?
Old May 9, 2007
mike21190's Avatar
http://www.crutchfield.com/S-Iicx74a...0&I=003HONK809
first, you need to take off the pieces surrounding your shifter. Just pull them up and they come off. Then you will see two screws by the cupholders but inside the piece you just took apart. Unscrew them then pop out the sides of that piece. Then if you could just pull it out. Underneath there should be two screws to the metal bar. Unscrew them then get a flathead screw driver to pop out the center console. You will need to remove the old stereo and the adapter and put in the new adapter with the new stereo in it. Plug everything back up. Hope this helps if you need more help just ask.
Old May 9, 2007
Seiber84's Avatar
Fiberglass Guru
Seiber84 is on a distinguished road
I just got by double din METRA trim piece off of ebay for about 20 bucks. If you are only going to utilize 1 din you may be better off with something like this.
http://cgi.ebay.com/Honda-Civic-01-0...QQcmdZViewItem
Old May 14, 2007
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
I have the Crutchfield master sheet info for a 01-up Civic Coupe and Sedan on my computer if anyone needs it. Let me know and I can email it to you.
Old May 16, 2007
wragen22's Avatar
Where can I get the panel tool to remove the stereo?
Old May 17, 2007
Bojo makes nice plastic removal tools. My recommendation on removing these decks is to put a glove (snap-on, mac, crafstman or whatever) on your hands and push the whole assembly out from the backside after you've pulled the 8mms. The plastic tool can help in loosening the clips but pushing the deck from behind is a good way to get the heater/radio out.
Old May 17, 2007
No need for a panel tool, just use a tiny screwdriver and pop it off. If your careful you won't hurt anything.
I emailed you that sheet a few days ago.
Old May 17, 2007
Seiber84's Avatar
Fiberglass Guru
ChristmasPie is right.
Once the two bolts are removed....I left them out. Now whenever I need to access wiring or anything i Just removed the trim piece containing the Cig Lighter and just push from behind and it comes out with no fuss.
Man Up. No gloves necessary though. Hah.
Old May 17, 2007
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
A little screw driver will leave indentations in the vinyl.
A putty knife, maybe 3/4-1" wide, works great.
Old May 17, 2007
Eh, just trying to make it easier for the masses. If you do pull these enough (especially same car) they get easier and easier and yeah you don't need anything but one bare hand after those bolts. But if it's your first one you'll likely save yourself a bloody knuckle or two. Of course not that there's anything wrong with getting a little bloody.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
sch2cm
Jul 21, 2015 09:58 PM
robbie374
Jul 7, 2015 02:56 AM
